Pushing Brake piston back in
Dr Nick
PostPosted: 18:17 - 26 Mar 2004    Post subject: Pushing Brake piston back in Reply with quote
After taking me rear wheel off to get a new tyre put on, i accidentally pulled the brake lever, pushing the pistons out Confused.
Anyone got any ideas about how to get it back in?
I've tried pushing but it doesn't work Sad
Any Help would be appreciated
Thanks
is that it
mr jamez
PostPosted: 18:40 - 26 Mar 2004    Post subject: Reply with quote
You mean right out as in fallen out? or just too far to get the pads in again? Razz
Use a thin bit of metal and a clamp if you can get it right onto the pistons, otherwise I would do the same but just push either side evenly with your hands. Just do it slowly and it should be ok.
Robby
Dirty Old Man
PostPosted: 20:21 - 26 Mar 2004    Post subject: Reply with quote
I use a G clamp.
Milo
PostPosted: 20:43 - 26 Mar 2004    Post subject: Reply with quote
Good and luck come into mind...
I use some of those long-handled adjustable pliers for a good amount of force. When my brakes seized it took me and my Dad using a couple of these things to get them pushed back in.
definitely a mistake I'm sure you won't be repeating anytime soon!
Adam
Shaft drives rule. Razz
rizzla
PostPosted: 20:55 - 26 Mar 2004    Post subject: Reply with quote
try taking the brake fluid resoviour cap off first then use a screwdriver to push the pistons back. this should work watch that no fluid pours over the top of the resoviour and that no water or damp get in
Dr Nick
Got hold of a G Clamp, all sorted now. Thanks for your Help.
is that it
The last post was made 22 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.89 - MySQL Queries: 14 - Page Size: 46.83 Kb
