Bandit SAK9 Neutral problem
bgfs
PostPosted: 20:12 - 20 Dec 2011    Post subject: Bandit SAK9 Neutral problem Reply with quote
I have a Suzuki 2009 GSF650 SAK9 which has done 14,000 miles. I have a problem when selecting neutral. The bike goes into neutral (proven by letting the clutch out), but the neutral indicator doesn't come on. I have to try a number of times and sometimes a slight downward pressure (not enough to take it out of neutral) get the neutral light on. This is the second time this has happened. The first time the dealer repaired it but didn't explain what was wrong. Anyone got any ideas whats wrong and how to fix it?
BGFS
Dazbo666
PostPosted: 20:30 - 20 Dec 2011    Post subject: Reply with quote
Dodgy bulb ?
Loose connection(s) ?
Phunked sensor / switch ?
Word of the day : DILLIGAF
bgfs
PostPosted: 21:48 - 20 Dec 2011    Post subject: Reply with quote
Bulb is fine. My theory is the switch but how do you get at it. It would appear that the gear change is connected to a rod which connects to the gear box. How easy is it to get inside and at the switch?
BGFS
HD
PostPosted: 22:20 - 20 Dec 2011    Post subject: Reply with quote
Does it need changing? Surely if you're in neutral, you know you're in it? Confused
orac
PostPosted: 16:19 - 21 Dec 2011    Post subject: Reply with quote
^what about the safety circuits that cut the engine when the stand goes and the thing is in gear/not showing neutral^
i would take the snensor of and give it a good spray with contact cleaner, let it dry and check the contact etc. if they have some corrocion gently rub them with some fine wet and dry to remove the corrosion.
Walloper
PostPosted: 16:37 - 21 Dec 2011    Post subject: Reply with quote
KAPITALS, KAPATALS, KAPATALS. Paleeeeease
They cost the same as all the little lower-case letters.
Rolling Eyes
HD
PostPosted: 18:16 - 21 Dec 2011    Post subject: Reply with quote
Isn't that just the stand switch? Doesn't the neutral one purely show if your in neutral or not and doesn't affect the engine?
DJP
PostPosted: 19:44 - 21 Dec 2011    Post subject: Reply with quote
My 1250 Bandit's just the same (and has the same basic engine unit).
It's done a similar mileage, too.
Where is the neutral switch on these engines? I suspect that it's just the switch getting covered with crap.
HD
PostPosted: 20:08 - 21 Dec 2011    Post subject: Reply with quote
On the bandit 400, it is just beside the gear linkage. Shouldn't be far from there.
On mine though, it looks like it is put in and hot glue injected around it. Maybe you can remove the whole unit or it was a bodge Idea
BanditsHigh
Worse than a woman
PostPosted: 20:41 - 21 Dec 2011    Post subject: Reply with quote
Neutral switch will usually consist of a circular blob with a couple of wires, mounted on the end of the gear selector drum (left side of engine under sprocket cover.
Usually two machine screws hold it in place ... has a copper/brass contact on the inner side ... selector drum has a spring and ball bearing which make contact with (guess) when in neutral.
Easy to take off and clean ... just watch out for the ball bearing ... also check the connector where it's plugged in.
orac
PostPosted: 07:46 - 22 Dec 2011    Post subject: Reply with quote
the switch, clutch switch and side stand switch make most of the safety circuit, on the 400 the side stand also has reley, and there is a diod that feed the kill from the cluctch switch (if i remember correctly)
also most bike now dont have just a neutral switch, i now the v-valve 400 bandit have a gear position switch with evry gear and neutral with a copper pad. the front sprocket has to be removed to get to it. it has a small retaining bracket and 2 machine screws that hold it in place
The last post was made 8 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: enterprise (www) - Page Generation Time: 2.13 Sec - Server Load: 1.07 - MySQL Queries: 16 - CDN Objects: 41 - Page Size: 71.74 Kb
