Newbie here: Bike wont start. just rapid clicking noises :s
Meteor_Tesh
PostPosted: 14:58 - 22 Dec 2011    Post subject: Newbie here: Bike wont start. just rapid clicking noises :s Reply with quote
Hi every one. I'm fairly new to biking. Passed my test in August, and got my first bike in September 2011. Yamaha Fazer 600. (2003)
since I bought it, I have ridden it pretty much every day (except for in the rain) up until around two weeks ago, when the weather here (Bolton) got very cold and ice was every where. So for the last two weeks (or just over) my bike has been sat in my garage. I tried to start it a couple of days ago, and at first, the egine just didnt start up, but the usual sound when pressing the ignition switch still came out. After a few times of trying, including using the choke, putting it into gear while holding in the clutch etc, when ever I press the ignition switch now, I just get a fast clicking noise (sometimes mixed with the usual engine about to start sound) from around the battery area. Is this a flat (or very low) battery, which is what I have read on many other post?
The only thing that makes me think otherwise is that it has only been sitting there for two weeks, as opposed to months like what others have described.
When I bought the bike, the previous owner had a new battery installed so it's not even a year old yet. another reason for my doubts.
But as stated, I'm new to all of this, so just looking for some guidance on the problem. Maybe the cold weather just flattened it? Any help will really be appreciated.
Thanks in advance.
virus
PostPosted: 15:18 - 22 Dec 2011    Post subject: Reply with quote
charge the battery as a first port of call then try again, If that doesnt work then find the part that is clicking (starter solenoid, basically a high current relay).
Short the 2 large terminals together with a screwdriver to bypass the solenoid (make sure clutch is in, choke is on etc). If it starts when bypassing the solenoid then chances are your solenoid/wiring from start button to solenoid need replacing, unlikely to be wiring through if its clicking, that means its connected.
p.s. it will spark when you bypass the solenoid, dont worry about it.
John
own: 81 xs1100g...
Lynxx
PostPosted: 15:23 - 22 Dec 2011    Post subject: clicking Reply with quote
Well its either a low/ bad battery, a Solenoid or your starter.. While trying to start it tap the starter with the handle of a screwdriver. if it still clicks locate the Solenoid (follow the red wire from the battery to the small cylinder part) that's your solenoid, grab a wrench and put it in between the 2 posts on the solenoid, This will bypass the solenoid and if the starter / battery is good it will start or turn over the engine. IF it still doesn't start get a new battery or try a battery from another motorcycle which you know is good.
Current: 1992 Suzuki GSF400V - 1984 Honda MTX200 (SOLD) - 1975 Honda Xl350 (SOLD) - 1993 Honda CB250 (SOLD)
Meteor_Tesh
PostPosted: 15:53 - 22 Dec 2011    Post subject: Reply with quote
Hey guys thanks for your replies. Just tried the selenoid and its pretty much impossible on my bike. The two 'towers' are covered over by rubber, and then a thick red wire (which attached to my batter) runs over them aswell, I dont the wire is too long either, meaning, I can't even move it to the side or anything to put a wrench or screw driver there. Luckily christmas is coming up and I will be seeing my uncle who also has a bike, I'll borrow his charger andcharge my battery to see if thats works. Will post back with the result in a few days.
Thanks for your time and help.
virus
PostPosted: 15:55 - 22 Dec 2011    Post subject: Reply with quote
Should be able to slip a flat blade screwdriver under the rubber caps to connect the 2 posts.
John
own: 81 xs1100g...
doggone
PostPosted: 16:02 - 22 Dec 2011    Post subject: Reply with quote
Two weeks is ample time for the battery to have gone flat in cold weather.
Most bikes these days have immobilisers/alarms/digital clocks all slowly draining it and small batteries don't keep charge long anyway.
bwprice100
PostPosted: 16:24 - 22 Dec 2011    Post subject: Reply with quote
First off I would charge your battery.
I have attached a document that shows how I test the starter on my BMW which I hope may be of some help.
Brian
www.eBolt.co.uk www.ToolRoomChucks.co.uk
My bikes 1956 BMW R26 250cc, !981 BMW R80 (was a TIC ex plod), 1994 R100RT, sold my 1981 Yam XS 250
EazyDuz
PostPosted: 16:56 - 22 Dec 2011    Post subject: Reply with quote
when you do get it going, try to start the bike up once a week and let it idle for a while if you arent going to be using it over winter. I left mine for about 16 days and it still started but didnt start as quickly as it normally would and the starter was rotating slower. Let it idle for 25 minutes, now when i start it it fires up instantly from cold.
Meteor_Tesh
PostPosted: 17:26 - 22 Dec 2011    Post subject: Reply with quote
Thanks for all the tips.
BWprice, thanks for your document, I'll print it off and have a go at it tomorrow during the day.
Doggone, Yes I guess your right, as my bike has an alarm/immobiliser combo installed aswell.
When switching the ignition on with the key, theheadlights, dash board etc all light up as normal? can this still happen even with a low battery?
(ofcourse, when i have been trying to start it, i turned of the lights, just incase they were sapping any power)
Kwaks
I'm not a fast rider
PostPosted: 17:36 - 22 Dec 2011    Post subject: Reply with quote
you have checked the killswitch I presume?
www.cliqueycuntsmcc.co.uk
bwprice100
PostPosted: 17:41 - 22 Dec 2011    Post subject: Reply with quote
Your welcome, let us know how you get on.
Yes, a lot more current is needed to turn the starter
There is probably, what is called, a load shedding relay in the circuit which should switch most things off so the starter can get all the juice.
Brian
duzzer
PostPosted: 19:02 - 22 Dec 2011    Post subject: Reply with quote
my fzr 600 was doing this not long ago, i checkt the battery (ok) checkt the relay (ok), it turnd out that the brushes on the starter motor had crap on them, cleend them down with WD40 and used a small amount of copper grease on the brush and started to work 100%
Meteor_Tesh
PostPosted: 13:28 - 23 Dec 2011    Post subject: Reply with quote
Hey Every one. I want to thank you all for your help and comments. I really appreciate it. I can now confirm that it was indeed a flat/low battery.
Luckily I went to visit my uncle yesterday evening who also rides a bike and he has loaned me his charger. I left it on charge over night, installed the battery again and it starts up better than ever now. pretty much instantly.
Thank you all so much. Only problem is the weather today in Bolton is terrible!!! so I still cant get out on it yet Sad
but atleast the problem is solved
The last post was made 14 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.25 Sec - Server Load: 1.54 - MySQL Queries: 17 - Page Size: 82.86 Kb
