newbie, help! gear oil?
samurai
PostPosted: 23:41 - 30 Mar 2004    Post subject: newbie, help! gear oil? Reply with quote
hiya,
i'm a total newbie to bikes and have been pootling around on my new NSR125-RR for 2 weeks now but i need to ask a question, possibly a stupid one!
i was looking round my bike and there is a small panel low on the right hand side of the fairing (circled in pic). i took it off and had a look and there is a small reservoir with a min/max guide on it. this reservoir is empty.
i squeezed the clutch and a cable near the reservoir moved, should i have gear oil in here? i do feel a bit of a clunk when changing into first from a standstill if i don't put enuff revs on. changing when riding seems ok but coz i'm new & this is 1st bike, so can't compare it to anything ridden before!
any advice greatly recieved!
Karma samurai Karma
McJamweasel
BCF Junkie
PostPosted: 23:58 - 30 Mar 2004    Post subject: Reply with quote
Yes, there should be oil in there. Was the bike on its sidestand when you looked at the oil level? If it was then try again with the bike vertical. If it is low then fill it up with some light gear oil.
The clunk could be down to a slightly loose chain, or it could just be normal.
ZaphodBeeble
PostPosted: 05:38 - 31 Mar 2004    Post subject: Reply with quote
The clunk you get is quite normal and usually shows that your clutch is in good condition. As McJam said, make sure the bike is completely level when you check the level indicator. Thumbs Up
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
samurai
PostPosted: 12:15 - 31 Mar 2004    Post subject: Reply with quote
cheers guys, will get some oil in there sharpish!
thanks
Karma Samurai Karma
Kris
PostPosted: 12:21 - 31 Mar 2004    Post subject: Reply with quote
If it is the gearbox oil level that you are seeing remember two things. Firstly the level should only be checked when the bike is cold and oil has settled. Secondly, on the NSR the oil should be checked with the bike upright, not on the sidestand. It does make a difference to the oil level, and thus it is easy to overfill the bike.
Good luck Thumbs Up
www.prisonplanet.com
needa400
PostPosted: 15:56 - 31 Mar 2004    Post subject: Reply with quote
Not saying you are stupid, but dont make the mistake some people make. It is called gear oil, so dont put two stroke oil in as some do. Lol
Very Happy
needa
I was here, now I'm not, coz I covering the missus in me special man snot!
Last-of-the-nsr's
PostPosted: 16:50 - 07 Apr 2004    Post subject: Reply with quote
Is it bad to go over the max mark for gearbox oil?????
needa400
PostPosted: 22:40 - 07 Apr 2004    Post subject: Reply with quote
Not extremely bad, but you should aim for halfway between max and min levels. Shouldn't do any damage though. Just drain a bit out!
The last post was made 21 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 54.54 Kb
