"Operation Ugly Suzi" - 1988 GSX600F rebuild
eddclarke
PostPosted: 17:25 - 05 Mar 2012    Post subject: "Operation Ugly Suzi" - 1988 GSX600F rebuild Reply with quote
Following on from this thread:
https://www.bikechatforums.com/viewtopic.php?t=239894&start=25
I will be using this thread as a diary of what has been done to this bike. The goal is to get it on the road and use it as a reliable commuter.
Here is how it looked when I got it back to mine
https://www.bikechatforums.com/files/suzi_114.jpg
https://www.bikechatforums.com/files/suzi2_120.jpg
The first job that I had to do was get shot of that headlight!
Second job was connecting up a battery and seeing what happens... the lights all work but there is a loud clunk when I hit the starter. I think it may be down to a dodgy connection somewhere (the bike has been stood in a shed for a couple years). Any advice would be very appreciated!
The list of bits to do is as follows:
Trace electrical fault
Fit new headlight unit
Strip and rebuild front and back brakes (the front master cylinder was full of nuts and bolts Rolling Eyes )
Fix the hole in the side of the tank/replace tank
New clutch perch needed
New C&S
Polish the wheels
Paint engine case
and a million other small jobs...
Here is how it stands now:
https://www.bikechatforums.com/files/3_146.jpg
https://www.bikechatforums.com/files/4_278.jpg
As you can see, the frame is in good condition!
Honda XR125L 06 ----> Yamaha FZ6 05 + ex SAS XR250 --> VFR800 + XR250r
Gazdaman
I did a trackday!!!
PostPosted: 20:14 - 05 Mar 2012    Post subject: Reply with quote
Starting problem probably is an electrical connection related to the starter relay or solonoid. One way to find out if it's anything more serious would be to try and bump start it.
And good god that bike's hideous.
Gaz
Ichy
PostPosted: 21:18 - 05 Mar 2012    Post subject: Reply with quote
Can I just suggest that before you do anything else that you take off the timing cover and try and turn the engine over by hand?
Does the neutral light come on?
eddclarke
PostPosted: 21:27 - 05 Mar 2012    Post subject: Reply with quote
good idea, will try that tomorrow!
nuetral comes on, yes.
regards
Ed
nickyboy4
PostPosted: 07:22 - 22 Mar 2012    Post subject: Reply with quote
Bought and sold t
one of these last year with a starting problem, turned out to be the right hand switchgear, you can use a bandit one because there are more of them around!
The last post was made 14 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.03 - MySQL Queries: 16 - Page Size: 45.56 Kb
