Pass the F***ing Hammer! NOW!
Diehard
PostPosted: 23:02 - 05 Apr 2004    Post subject: Pass the F***ing Hammer! NOW! Reply with quote
Well another day gone and another day fiddling with the NSR. After giving up on changing the bearings myself, I started to get quotes for the work to be done for me, and low and behold, someone had an 1989 NSR complete engine, with only 9,000km on the clock. So I had to have it. Anyway, the engine is practically new and I was thinking all of my problems are over...Wrong. Got the engine back and found that instead of there being 3 yellow wires and 1 green from the generator (as there is on my old engine), there was 2 yellow and one green...Um...Ok so I tryed to change the generator coil, which I found was too big for for the new generator. So I Fitted the engine anyway and left a wire off (just to see). After long hours of this I went to start the bike, it sounded different, not as violent as before, but it was turning over. Anyway out of interest I switched on the lights, then nothing. I'm sure I saw a flash, so now I have no LEDs, no starter life, no nothing. Not even the power valve motor moving on the turning of the key. The main fuse looks fine. Any ideas, I'm hoping it ain't the CDI because I don't wanna spend more if I'm going to just sell it on. Also whats the best way to remove the generator??? Please help someone because I have really had it!!! Evil or Very Mad (I nod to keith) Wink
If I Die... I Die!
ZaphodBeeble
PostPosted: 01:56 - 06 Apr 2004    Post subject: Reply with quote
Tough luck mate. You really ain't having a good time with that are you? If you got a flash then I say that something had blown, maybe it is the CDI as they are quite weak and can't handle much of a charge if they are wired incorrectly or if they receive a surge. I can't really help you without seeing the bike for myself but I can suggest that you smell all of the components for that specific electrical burnt smell. Then at least you will know what the problem part is. Thumbs Up
Or you can sell the bike to me for £5 and I will collect it. Razz
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
Diehard
PostPosted: 12:02 - 06 Apr 2004    Post subject: Reply with quote
£5...Well...No I shall resist! I will get it fixed. But after going through the manual I think the CDI has gone! Sad But I wouldn't have thought it would shut all electrics off (neutral light, servo-motor etc). Gonna see if I can get one today. But at the mo I really need a rotor puller, so I can exchange the flywheels and at least have a matching electrical harness! Oh I really am having fun Shocked .
If I Die... I Die!
Diehard
PostPosted: 00:04 - 11 Apr 2004    Post subject: Reply with quote
YES! The CDI wasn't blown...I had pulled out the ignition switch wires unknowingly Embarassed ! Anyway got it all going today (touch wood). The new engine is a f***ing beast!!! Twisted Evil It goes along all nice then... The front end starts to raise and the thing shoots off, your in 5th gear before you know it (I never got to use fifth on my old engine). It will easily red-line in 6th if you ain't careful. It will take some getting used to but hell, if I don't die I'll have fun. It's only done 9,000km. Oh by the way, are the Italian imported NSRs faster in any way? This engine is actually off the unfaired NSR125F 1990, not RK like mine (hench I had to change the flywheel and gen). I got it off an Italian mechanic that brought it over from Italy with him. Just a thought because as I said it flys (and I'm 18 stone too)!
If I Die... I Die!
PostPosted: 00:19 - 11 Apr 2004    Post subject: Reply with quote
Judging from my NSR125F engine, it is downgeared compared to the R models (presuming you are using the sprocket that was on it). Whether it makes the same or less power than a faired one is another matter.
Diehard
PostPosted: 00:30 - 11 Apr 2004    Post subject: Reply with quote
I used my old sprokets from the other engine, I can't remember the number of teeth on them. But for an engine that looks identical, it is 110% different, alot more violent, thus, alot more fun Twisted Evil (you can tell I'm chuffed). By the way, good to hear your self (G), ste/alex are doing good (bet you've heard that way too much recently). Thumbs Up
If I Die... I Die!
PostPosted: 11:55 - 11 Apr 2004    Post subject: Reply with quote
Is this an NS125 or an NSR125?
If it is an NS125 then UK models were a pig to derestrict (basically almost impossible to do the job properly). An imported engine would have the full power valve system.
If it is an NSR125 from the early 1990's then only a UK model would be restricted. Any from any other market would be full power.
Diehard
PostPosted: 00:46 - 12 Apr 2004    Post subject: Reply with quote
Mine is an NSR125R, and the new engine was from an NSR125F, almost identical, appart from the wiring. I was sure my original engine was fully deresricted, but still lacked power, this engine is like riding something twice as powerfull! I don't know if there is any internal restriction (in the crankcase I mean).
If I Die... I Die!
PostPosted: 11:37 - 12 Apr 2004    Post subject: Reply with quote
The only difference I know of is that the F model has a lower power alternator.
The last post was made 22 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 62.09 Kb
