GPz fuel sender wiring
andym
PostPosted: 10:05 - 13 Feb 2012    Post subject: GPz fuel sender wiring Reply with quote
Hopefully a quick easy question for Sunday morning.
Does anyone know the wiring route of the GPz750 fuel tank sender, I've got the sender off, there was a white and yellow wire that had been cut and a spade with no wire attached.
I tried connecting it up to a battery and through the fuel dial, there is 3 wires going into the fuel dial and I've tried all combinations and none of them work properly. when I connect 2 of them up the gauge jumps straight to the top and if I move the fuel level float the wire inside the sender ends up glowing, which I know would probably be a bad idea in a tank of petrol.
Should there be something between the battery, sender and the gauge that reduces the power?
andym
PostPosted: 10:07 - 13 Feb 2012    Post subject: Reply with quote
I mean Monday ahem Embarassed
bikenut
PostPosted: 15:08 - 13 Feb 2012    Post subject: wire Reply with quote
:karma: hi dude,
a manual for this bike on site?
yes usually, a voltage regulator or dropper, so instruments work on less than battery voltage.
you may have buggered many things now, sender wire potentometer glowd red hot!!!!!!!!!!!!!!
The last post was made 14 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.33 - MySQL Queries: 14 - Page Size: 35.44 Kb
