HOW2: Adjust Tappets & CCT (Honda 'Benley' CB/CD/CM twin
SnowTigeress
PostPosted: 09:24 - 09 Mar 2012    Post subject: HOW2: Adjust Tappets & CCT (Honda 'Benley' CB/CD/CM twin Reply with quote
Haynes Manual, under 'Routine Maintenance', Page 28: "Four Monthly or 2,500 miles" (just for reference) Tef says that's every other oil change, that should be done at about 1,250 miles. But Tef reckons should be done every 1000, to be on the safe side, and worth doing Tappets & Cam-Chain tensioner, with each oil change, at least for the first few thousand miles of owning the bike, to tell how much adjustment they need. We've also had a couple that have 'wound off'; so worth keeping an eye on. So, what the book says:-
MrHaynes wrote:
1 Adjust Valve Clerances
The engine must be cold for the valve clearances to be checked accurately. Place the machine om it's centre stand on level ground, then raise or remove the seat, withdraw if necessary the side panels & remove the petrol tank.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2523.jpg
Simple enough; seat up, petrol 'off'; disconnect petrol hose at tap; pop the side panels; undo tank bolt, carefully lift the tank off, lift the plug caps off the spark-plugs and tuck the leads up out of harms way.
MrHaynes wrote:
Remove its two retaining bolts, then remove the cylinder head cover with its thick rubber gasket.
THIS is the fiddly bit!
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2524.jpg
Two chrome bolts on top of the rocker cover are easy enough (10mm AF Spanner. A cranked one helps; or a socket, but a 6 sided one is reccomended. A 12-point socket can 'slip' as the chrome nuts are a bit rounded on the corners, being 'cosmetic)
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2525.jpg
There isn't much room around the top of the engine to get the rocker cover out, and with the rockers inside, it can be rather annoying, and the ignition coils and brackets all get in the way!
TRICK: is to 'roll' the cover forwards over the rockers, so that the curvie bit in the front of the cover goes around the frame tube...
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2526.jpg
THEN, you can rotate the cover out of the gap, sort of pivoting around the frame tube. EASY! (when you know how!)
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2529.jpg
MrHaynes wrote:
Disconnect & remove both spark-plugs.
Oh! Already taken the leads off! Meanwhile, removing the spark plugs is the topic of another How2: Remove & Refit Spark Plugs!
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2535.jpg
And out they come. Remember to do both sides, and worth checking them against the book, while they are out. (Page 115!)
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2570.jpg
Ang giving them a quick clean, & checking the gap.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2569.jpg
MrHaynes wrote:
On CB125T,T2,TA&TB models, remove the two contact breaker inspection cover screws ans remove the inspection cover and it's gasket. On CB125TD, CD125T & CM125C models, unscrew both inspection plugs set in the crankcase left hand cover.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2536.jpg
Simple enough.
MrHaynes wrote:
Rotating the engine anti-clockwise by means of a spanner applied to the alternator retaining bolt,
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2540.jpg
OK, A deep socket then! & A torch to see all these 'ere marks theyz babbling about.....
MrHaynes wrote:
watch the machined slots in the camshaft left hand end and timing marks visible through the apature in the contact breaker backplate (CB125T,T2,TA&TB only) or through upper inspection apature (CB125TD, CD125T & CM125C). When the T1 mark (CB125T,T2,TA&TB,CD125T & CM125C) or TL mark (CB125TD, only) is aligned with the fixed index mark on the crankcase left-hand cover, and the camshaft slot is in the 3 o'clock position, the left hand cylinder is at TDC on the compression stroke, and the valve clerances are ready to be checked.
Marks?! TL, TF, TR, TLDR!?!?!?!? WHAT! "TEF! Wazaal this mean?"
Teflon-Mike wrote:
You need to rotate the engine round its cycle so that the valves are closed, and the cam has taken all pressure off the valve before you check the tappet clerance; what's called 'on the rock' where the rocker can actually be wiggled a bit..... So, you rotate the crankshaft, until the T1 or TL marks can be seen in the little window at the top; That means that the piston is at top dead centre, only it can be at top dead centre between the compression & power strokes, or top dead centre between the exhaust & induction strokes, so you also have to watch the timing marks on the cam shaft to tell which one it is. You want it to be between the compression & power strokes, becouse that's when the valves are both closed, and the tappets 'on the rock' the gaps at their widest point, where you can measure them. THEN you wind the motor on 180 degrees of the crank, or 90 degrees on the cam, which puts the right hand cylinder at top dead centre between the compression & power strokes, so you can check that cylinder's clearances.
Yeah! "TEF! Wazaal THAT mean?"
Teflon-Mike wrote:
Look at the slot in the end of the cam-shaft. When its pointing towards the back of the bike, like THIS
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2542.jpg
Teflon-Mike wrote:
Check the tappets on the Left Hand Cylinder. When it is pointing straight up, like THIS
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2543.jpg
Teflon-Mike wrote:
Check the tappets on the Right Hand Cylinder.
Oh, RIGHT! Why didn't you just say that to start with! Jeez!
Err... what about the CD & CM's though, they the same?
Teflon-Mike wrote:
Book gets to that in a minute. Doesn't say anything about the cam-slot again; just says on the CB rotate the crank half a turn, on the CD & CM a full turn.. so that would have the cam-slot pointing forwards on them, I think.
OK... I can do this bit, now. THANK-YOU! Bugger off back to your camera and take photo's!
MrHaynes wrote:
Using a 0.05mm (0.002") feeler guage, check the clearance between the top of each valve stem, and it's corresponsing rocker. The feeler guage must be a light sliding fit with the rocker and valve stem just nipping it.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2544.jpg
OK, so got the cam shaft slot pointing the right way; give the rocker a little 'wiggle', check that it's 'on the rock'. If it's tight, then either the tappet clerance has closed up, which isn't good, or you haven't got the timing marks set straight! So wind the crank round again and try again, wiggling the rocker until it does go loose, or you are sure you are at the right 'timing'.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2545.jpg
Sliding the blade between the tappet & valve, it's sort of a 'feel' thing, you cant explain. Blade ought to be kind of 'stiff' to tugg through the gap.
If you aren't sure; pick the feeler guage blades a size up and a size down from the one you need, and the smaller one should slide really easily, larger one not go in at all.
MrHaynes wrote:
If adjustment is necessary;
On this occassion it wasn't; so I adjusted some tappets on an engine we had 'lying around' that wasn't in a frame!
MrHaynes wrote:
slacken the locknut.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2578.jpg
MrHaynes wrote:
and turn the small square headed adjuster to obtain the correct setting
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2579.jpg
I did this with the feeler guage under the adjuster. Make sure that the rocker is all the way up, then screw the adjuster down. & you will feel when it grips the guage.
When its 'set' wind the lock nut back down with your finger, then slide the feeler guage in and out to make sure it is properly set.
MrHaynes wrote:
Tighten the lock-nut, holding the adjuster at the same time to prevent it from moving
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2582.jpg
MrHaynes wrote:
Rechecking the gap after tightening the lock-nut
WARNING: the adjuster has a VERY fine pitch thread and it is VERY esy to over tighten it and strip the threads. It is also very easy to not tighten the lock nut enough and for them to work loose....
Tef says; its easier to fix a loose nut, than a stripped one! After adjusting the tappets, go back round them all and do a final check-tighten. Then after a hundred miles or so, it IS worth lifting the rocker cover again, and again, just checking non have wound off.
So, inlet, on the Left Hand Side checked; can check the exhaust on the LH-cylinder.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2548.jpg
Then, rotating crankshaft to the timing mark for the other cylinder; inlet on the Right Hand Side:
MrHaynes wrote:
When both inlet & Exhaust valves are correctly set, rotate the engine one full revolution (360 degrees) and realign the marks on the CD125T and CM models and rotate the engine through 180 degrees on the CB125 model, to align the T2 mark (CB125T,T2,TA & TB models) or the TR mark (CB125TD only). The right hand cylinder will now be at TDC on the compression stroke.
Right! Yeah! What did Tef say? slot in cam pointing straight up on my CB125, forwards on a CD or CM.....
MrHaynes wrote:
Check & if necessary adjust the valve clerances of the second pair of valves.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2549.jpg
Then the Right Hand Cylinder's exhaust.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2550.jpg
And THAT is the tappets checked!
MrHaynes wrote:
Refit Cylinder head cover, checking that the sealing ring and sealing plugs are in good condition, and fit and tighten the bolts. If a torque wrench is available, tighten the cover retaining bolts to a torque setting of 0.8-1.2kgf m (6-9lbf ft). The petrol tank, side panels and seat can now be refitted unless thier removal is necessary to complete some other maintenence task. Do not fit the inspection covers or spark plugs
OK.... Tef says DONT do this! Do the cam-chain tensioner first! You'll see why!
MrHaynes wrote:
Adjust the Cam-Chain tension
With a spanner applied to the alternator rotor retaining bolt, rotate the engine anti-clockwise until the T1 mark (CB125T,T2,TA & TB, CD125T & CM125C models) or the TR mark (CB125TD only) is aligned with the fixed index mark on the crank case left hand cover.
Slacken the cam-chain tensioner lock-nut which protrudes ftom the rear of the cylinder barel, then retighten the locknut. The tensioner assembly should possition itself automatically to provide the correct tension as soon as the locknut is slackened. Note when retightening the locknut, the adjuster stud must be prevented from rotating. Do not touch the tensioner bolt ehich protrudes from the rear of the cylinder head.
Yeah, err... OK! THIS is what I did!
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2551.jpg
THIS is the bolt at the top, between the carbs that Haynes says "don't touch"! So I touched it! It holds the Cam-Chain Tensioner in place inside the engine, BUT, Tef says that the bit that needs to move to let the tensioner take up slack, MAY be pinched in place by this bolt... so to LOOSEN it SLIGHTLY... like as in maybe 1-Turn MAX.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2553.jpg
This is the Cam-Chain Tensioner stud & lock-nut they are talking about, between and beneath the carburettors.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2552.jpg
Loosen the lock-nut, not the stud.In THEORY, the spring in the tensioner mechanism, should pull the tensioner blade down and take up the slack in the chain, as soon as the stud is unlocked, and you may 'feel' it 'tug' as you undo the nut. BUT!
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2554.jpg
Known 'niggle' on these engines, and THIS was why we undid the bolt they say 'do not touch'; the tensioner mechnamism 'sticks'! So we slacken off that 'Do-not-touch' bolt, then give the top of the tensioner blade a 'little wiggle' to make sure it is 'free'.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2555.jpg
THEN with a spanner on the square of the tensioner stud, to hold it still, the lock nut can be retightened, and THEN, dont forget to nip up the 'do-not-touch-bolt'!
MrHaynes wrote:
If repeated attempts to adjust the cam-chain tension fail to quieten a noisy camchain, the engine must be removed from the frame and the cylinder head and barel removed, as described in Chapter 1 of this manual, for the tensioner components and cam-chain to be examined for signs of excessive wear or damage
Tef Says: If the cam-chain is noisy after repeated attempts to adjust it; its probably Donald-ducked. Tasking the head off and fiddling with it wont tell you much, and you'll have to split the crank-cases to loop a new (endless) Cam-Chain over the crank! DONT think "Oh! Well, I'll put up with the rattle!" It can be rather nasty when they SNAP!
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/101_0192.jpg
NOW: we can put the cover back on like Mr Haynes said to after doing the tappets!
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2556.jpg
Check the condition of the Rocker-Cover seal. These do NOT have to be replaced every time the cover is removed, but they do go hard with age, and the rubber seals on the retaining bolts are often forgotten.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2557.jpg
Re-Assembly is the reverse of removal! FAFFING FIDDLY! As removal align the curvie bit of the cover around the front down tube of the frame,
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2558.jpg
Then sort of twist the cover over the top of the engine. Tef says dont worry too much about the seal falling out of place, just yet, but dont let it snag or yank it, try and get it over the rockers with the cover.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2559.jpg
Then it can be tilted back over the rockers, careful to get the rubber seal between the case and the cylinder head.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2560.jpg
It will almost certainly be a swine, and fall out, but just be gentle.... and tickle it back into the rebate in the casing as you lower it into place
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2561.jpg
paying atension around that curvie bit, where it likes to pop out when you're not looking!
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2563.jpg
Then the cover bolts can be jiggled into place, screwed in, and then tightened down. The cover may need a little re-alighnment to get the screws in straight. Dont force them.
And then do the cover up evenly tightening down a little on each side in turn, so it goes down straight.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2566.jpg
Tef tells me THIS is what WD40 is REALLY for! (Not lubing chains, or losening rusty bolts, but) Spraying onto the electrics inside the magneto cover, before we put the cover caps back on, to keep the damp out.
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2568.jpg
Inspection caps back in. And refer to How2: Remove & Refit Spark Plugs!, if needed...
https://s1177.photobucket.com/albums/x349/snowtigeress/engine/imag2572.jpg
To replace the spark plugs! HT leads can then be put back on the plugs, and the tank and side panels re-fitted, and the engine 'run up' to check for nasty noises or leaking oil. and JOB DONE.
See, even a GIRL can do this!
Real bikers build their own Renovated and Riding a 1986 Honda CB125TD-C called the Pup. Full Licence
13/09/2012, 1994 Moto Guzzi 750 Strada
Can-Do Girl that does spanners TOO!
TheSmiler: binning it is better than going around a roundabout the wrong way
bikenut
PostPosted: 13:10 - 09 Mar 2012    Post subject: upsidedown Reply with quote
Karma nice pics, didnt read all text thought.
some more pics of valve springs would be good as pics suggest ( suggest only as pics need to be better ) that some may be upsidedown. ( left exhaust )
close coils of springs to head.
feedback and pics
bikenut
PostPosted: 15:33 - 11 Mar 2012    Post subject: valve springs Reply with quote
:karma: hi snow tigress,
please please please check valve springs for close colis to head position.
i looked at pics again just now and still thick that the left exhaust outer spring may be up side down.
if springs fitted upside down, then accelorated wear will happen.................cam chain.................?
please check..................perhaps an other biker may comment, in the interests of tigress and her engine.
over
bikenut
PostPosted: 11:47 - 12 Mar 2012    Post subject: Reply with quote
Karma hi dudes and tigress,
the fifth pic in this thread suggests that the left exhaust valve outer spring may be upsidedown.
the twentieth pic suggests that the right inlet valve outer spring may be upsidedown.
tried copy and paste but failed.
pic 36 shows head overhang that may foul plug socket and bugger plug thread.
as i said this nearly happened to me when i had long hair, im solar powered now but it HAPPENED. m of m and c did same thing and buggered there thread on left cylinder, it HAPPENED.
dont let it HAPPEN to you. Crying or Very sad
opinions as to valve springs being upsidedown welcomed. Very Happy
close coils to head, as stated in many manuals.
why?? Neutral Karma
some better pics for clarity would be good.
over
SnowTigeress
PostPosted: 10:54 - 13 Mar 2012    Post subject: Reply with quote
why?? Neutral Karma
over
Thanks for pointing that out,the engine in the bike is the one I stolen as the engine I did the tappets on is my engine which needs rebuilding....ill double check the springs when I do the rebuild.
now can we leave it at that please.
Also the spark plug one was because a certain friend,buggered up his threads....so just thought Id makes sure all other newbies don't do the same.
bikenut
PostPosted: 11:36 - 13 Mar 2012    Post subject: plugs etc Reply with quote
Karma me likewise, will co. Karma
There is a gap of 3 years, 109 days between these two posts...
Teflon-Mike
tl;dr
PostPosted: 17:42 - 30 Jun 2015    Post subject: Reply with quote
Since Snowie wrote this, we have (because some bugga lost the small beak-nose adjustable she used to set the tappet adjusters here!!!!) invested in the Honda 'Special Tools' for the job. Remarkeably they are NOT all that expensive; and do make the job a tad easier, so following an ask in another thread, thought I'd offer the part-numbers:
Tappet Lock-Nut box-spanner: 07908-GE00200 -> £7.33 @ Dave Silvers
Tappet Adjuster Key: 07708-0030400 -> £3.80 @ Dave Silvers
https://www.davidsilverspares.co.uk/graphics/parts/077080030400_large.jpg
Actual tappet pt-no - for any-one suffering ones chewed by PO's using pliers or mole grips, is: 90012-333-000 (£1.92 @ DSS)
Tool fits all Hondas that use that tappet, which includes the CG125 I believe, and a bunch of other small or old Hondas
I got the pair from Dave-Silvers; they were 'special order' so took a couple of weeks to get here; but a better bet than the rather optimistic timing and 'chance' of e-bay items advertised for other models in other countries; but depends who's listing what when you look, I guess.
I got both, as there's no picture for the lock-nut tool, & I supposed that the key depended on it... it don't, so you don't need to get the set, just the (cheaper) key, so long as you have the 10mm AF spanner you used to take the rocker cover off!
The last post was made 11 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 86.12 Kb
