neutral switch in the gearbox
coolfox1
PostPosted: 15:02 - 15 Apr 2004    Post subject: neutral switch in the gearbox Reply with quote
Not sure if anyone knows !, but have a none working neutral light, checked the bulb and the wiring, also jumped a earth feed into the cable as it comes out of the gearbox and it works ok, so I guess it's the switch in the gearbox, question is this a case of gear box opening up job or should I be able to pop the switch out, have tried to pop it out but no joy, didnt want to force it !.
Not sure I'd want to open the gearbox up as kinda expect springs cogs and bits to start popping out lol
it's a 2000 nsr 125 btw.
rizzla
PostPosted: 22:01 - 19 Apr 2004    Post subject: Reply with quote
You have to unscrew it using a deep socket you may want to drain the oil before doing this or block the hole.
coolfox1
PostPosted: 22:15 - 19 Apr 2004    Post subject: thanks Reply with quote
Thanks I'll have a look
Ian
The last post was made 22 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 34.57 Kb
