| dextersaurus |
 dextersaurus World Chat Champion
 Posted: 19:17 - 25 Mar 2012 Post subject: CBR600f cam chain rattle? vid included *update - second vid! |
Hi guys.
Getting my CBR back on the road after i had a mishap with it in the garden. it's still misfiring but that's a carb issue i'm sure.
I'm now faced with a few problems.
I've taken the tensioner out and primed it, stuck it back in and the noise goes away till i restart it...
here's the vid - https://www.youtube.com/watch?v=N_tGcLwp_Ho
Now. When it's running, i get a lot of white/blue smoke from the exhaust when it's revved, maybe just because it's been sitting for a while?
From the exhaust, i also get a lot of black water, which has no smell to it, dripping from it. it revs cleanly but just doesn't seem right. i'm hoping this is just condensation from the 6-7 months it's been sitting.
Can anyone shed some light on this one?
Is it worth spending the £60 on a manual cam chain tensioner to sort this?
Going to be cleaning out the carbs anyway this week, but if this doesn't solve it.... i'm now worrying about timing.
Dunc
| sickpup |
 sickpup Old Timer
| dextersaurus |
| dextersaurus |
 Posted: 22:47 - 25 Mar 2012 Post subject: |
i'm gonna get another video once i get a new battery since this one's not holding charge, and i'll show that it sounds fine when it's started cold.
I'll see what the opinion is then
Dunc |
| Pete. |
 Pete. Super Spammer
 Posted: 22:59 - 25 Mar 2012 Post subject: |
Warm the engine until it rattles.
Take the M6 plug out of the back of the tensioner using an 8mm spanner. Now find a long thin flat-bladed screwdriver that you can comfortably fit inside the tensioner so that it engages in the slot.
Hold the screwdriver from turning and start the engine. You'll feel a tugging on the tensioner but hold it firmly to resist turning. If you get a rattle then GENTLY turn it to tighten the tension a small fraction of a turn (you will have checked which way to turn it before starting the engine I'm sure). Make sure you don't turn it to loosen the chain.
If your rattle stops the top end is fine and you need a new tensioner. Could be that the chain is worn and the tensioner spring has unwound until it no longer holds with enough spring-force. ____________________ a.k.a 'Geri'
| dextersaurus |
| Mikey3 |
 Mikey3 World Chat Champion
| lihp |
 lihp World Chat Champion
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| dextersaurus |
| dextersaurus |
 Posted: 17:48 - 26 Mar 2012 Post subject: |
Right. so i've started it cold with plenty choke and here are the results.
It can't be the pison smacking the valves as it's not making the sound anymore, so is this the tensioner problem then?
I'm more worried about the smoke, water and misfire. hoping it's just a carb problem...
https://www.youtube.com/watch?v=DXhR6J_Y8tk&feature=youtu.be
AS you can... hear/see... it sounds like a twin...
Dunc |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 00:11 - 27 Mar 2012 Post subject: |
Start from scratch here dunc.
Take off the carbs, take out all the jets and clean them thoroughly. I had a problem with mine that we couldn't get the float bowls to re-seal as the gaskets were fucked, so check that too.
As I said before, get a spare plug and check you've got a good spark on all the cylinders. Then replace all plugs.
Put it all back together, with FRESH fuel.
My bet is that the smoke is due to water in the fuel on idle and when revved the excess fuel thats getting into the cylinders because the carbs aren't working properly is washing the bores and that oil is being burnt.
Also, check the oil level as that could explain the smoke. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| dextersaurus |
 Posted: 18:43 - 30 Mar 2012 Post subject: |
SHE LIVES!
Cleaning out the carbs, and found that cylinder 4's idle jet wasn't in properly.... fell out as soon as i took the float bowl off.
Oops, those pesky little garden gnomes, playing with my bike.
So anyway, it's sorted now, but it does have a weak spark. put some standard plugs in and it refused to fire up. played about with it for a while without much luck.
So i put in some iridium plugs, and it fired straight up. Need to have a look at this, maybe a bad earth.
Anyway, it's all sorted and it runs well, sounds good, no worrying noises, and best of all, NO SMOKE!
I've missed it.
Need to wait another month now so that i can afford to put it through it's MOT and tax it now
Dunc |
| DrDonnyBrago |
| CB77 |
 CB77 Nova Slayer
| dextersaurus |
| Pete. |
 Pete. Super Spammer
 Posted: 09:58 - 31 Mar 2012 Post subject: |
Water dripping from the exhaust is just steam condensating on the cold internals. Get the engine and exhaust hot and it will stop. ____________________ a.k.a 'Geri'
The last post was made 14 years, 174 days ago. Instead of replying here, would creating a new thread be more useful? |
