Piston Kits
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
Scooby
Scrappy Doo
PostPosted: 17:50 - 19 Apr 2004    Post subject: Reply with quote
If you don't know the size of the bore then you need to measure it. The +'x' is merely for barrels that have been rebored, for example a +0.50 piston kit is for a barrel that has been rebored to +0.50mm. If you don't know the full history of the bike then measure the bore before you order a kit.
kev
I Hump Things
PostPosted: 20:46 - 19 Apr 2004    Post subject: Reply with quote
Take it you meen the X in RXS100, well that the the model of the bike the piston kit is for.
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
PostPosted: 23:41 - 19 Apr 2004    Post subject: Reply with quote
Not only the rings, but also the piston will be a different size. Cheats way to do it is to take the head off and check the size of the existing piston (stamped on the top 99% of the time).
priller
PostPosted: 08:45 - 20 Apr 2004    Post subject: Reply with quote
Doesn't work every time though, my rs had a 49.99mm piston and the new one was a 50mm piston.
PostPosted: 13:45 - 20 Apr 2004    Post subject: Reply with quote
Jammy-G wrote:
Bit worried about doing that as I don't think it has been off before and doing might make the existing ring fall to bits, and even maybe into the cylinder Confused
You do not have to take the barrel off (although if you just take the head off you will have to replace the head gasket). To change the piston you will have to remove the barrel, and if the rings are already broken such that they might fall off into the engine when you remove the barrel then you are likely to wreck the barrel if you continue to run the engine now. The ends of the rings would be quite likely to score the barrel.
priller
PostPosted: 13:49 - 20 Apr 2004    Post subject: Reply with quote
If you taking the barrel off don't forget to stick some rags down the crankcase mouth incase the rings are broken.
go_fasta
PostPosted: 15:41 - 20 Apr 2004    Post subject: Reply with quote
while we're on this subject, I have a CG125 which needs reboring and a new piston (it got seized up). The only piston I could get hold of is .75 oversize, so will it be ok if I just send the barrel to be rebored as long as they know what size the piston is? and how much would it cost?
cheers
i was going to start a new topic but i saw this and thought it would go better in here. someone tell me if i shouldn't have done.
If you cant fix it the first time
KICK IT HARDER!!!
PostPosted: 18:22 - 20 Apr 2004    Post subject: Reply with quote
Yes it will be fine, except that you are wasting a couple of rebore sizes. They will probably want the new piston with the barrel to do a good job of boring it.
The last post was made 21 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 75.3 Kb
