Pin locks/Fog City/Foggy Masks?
Which do you use?
Pin Locks
58%
 58%  [ 23 ]
Fog City
10%
 10%  [ 4 ]
Foggy Mask
23%
 23%  [ 9 ]
Other (please specify)
7%
 7%  [ 3 ]
Total Votes : 39
TUG
PostPosted: 22:04 - 10 Apr 2012    Post subject: Pin locks/Fog City/Foggy Masks? Reply with quote
I'm sick of my shitty pinlock, it only works if i adjust it with the visor closed and then lock the visor in place, as soon as i open the thing the pinlocks dont keep enough pressure on the inner visor thus mist in my lid.
Everyone has had to deal with this at one point and other than holding your breath, what was the best soloution?
Poll added.
EDIT: My skid lid is a shoei XR1100
Haz ER-5, innit!
daemonoid
PostPosted: 22:26 - 10 Apr 2012    Post subject: Reply with quote
Try washing the visor and the pin lock in warm soapy water. Rinse well, again in warm water. Dry the faces that are to be placed together slightly then install the pin lock in the visor.
Should improve the seal between the two a bit and may cure your problem.
current: ducati monster 750
TUG
PostPosted: 22:37 - 10 Apr 2012    Post subject: Reply with quote
The gap created when opening and closing the visor is greater than 5mm so it wont really help. I've tried alot of different things like flattening the insert again so it pushes against the pins more but again, didnt help with the same problem.
I want to buy a black visor at some point without pinlock posts.
Haz ER-5, innit!
MG
PostPosted: 22:44 - 10 Apr 2012    Post subject: Reply with quote
I got a pinlock free with my shoei raid 2. Didn't like how the top of the pinlock was in my line of sight, so took it out and bought a foggy mask. I would really recommend it, never steams up and keeps my nose warm in winter Cool
'03 Honda Cityfly 125 > '02 Honda CB500S > '98 Honda CBR600F
daemonoid
PostPosted: 23:30 - 10 Apr 2012    Post subject: Reply with quote
That's really odd! Did you fit it yourself? Sounds like the pins are positioned incorrectly... Only ever had the pre installed and they've been perfect. What kind of lid?
TUG
PostPosted: 23:32 - 10 Apr 2012    Post subject: Reply with quote
Lid came with them pre installed from a dealer so dont see why they fail, i have a spare clear one, maybe the tinted insert is fuxored?
Haz ER-5, innit!
Dazbo666
PostPosted: 23:39 - 10 Apr 2012    Post subject: Reply with quote
-I've used Fog City inserts in my previous (AGV V-Flyer) lid - a standard one in the dark visor, and a Hyper Optiks insert in my clear visor.
Both worked faultlessly for the 4-5 year life of the helmet, and I'd happily have them again.
However, my current lid has suffered a couple of pretty severe scratches across the visor, so it looks like it's going to be a replacement visor before I start thinking about any more Fog Citys in preparation for the summer.
-No experience with Pinlocks to date, but I've heard good things from those that use them.
-As for Foggy masks, I bought one some years ago, but could never get a comfortable, effective fit with the AGV lid, so its been returned to a cupboard drawer, unused, still with its original packaging
Word of the day : DILLIGAF
whitedevil
PostPosted: 23:58 - 10 Apr 2012    Post subject: Reply with quote
Sounds like you need to adjust the pins holding the pinlock in place.
remove the pinlock and turn the pins on the visor 180 degrees, then refit the pinlock.
Ive used them on several helmets and if fitted correctly they've never fogged up.
But the one in my avg does obscure my vision slightly around the edges at night if im crouched down looking out the top of the visor.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
TUG
PostPosted: 00:10 - 11 Apr 2012    Post subject: Reply with quote
Just pulled out my old shoei kit, i have some spare pins (black ones) and noticed the ones in the fucking visor are loose? excessive play side to side but if i pinch the top washer in they lock against the visor but a bit of wiggling later they come loose again, should i pull them out and put my new pins in? or will they just do the same, im well shit with this stuff lol.
Haz ER-5, innit!
TUG
PostPosted: 01:16 - 11 Apr 2012    Post subject: Reply with quote
getting a bit pissed off here, just fitted the new posts in the visor which are cunts btw, and one of them has gone loose again meaning that the fucking thing doesnt contact the insert propperly creating the gap as soon as i fit the visor to the helmet, pinlock for me are fucking useless tbh, think i'll just go back to fog city.
Looks like i'm not alone either.
Haz ER-5, innit!
fireyphoenix1...
PostPosted: 01:33 - 11 Apr 2012    Post subject: Reply with quote
i never rated shoei myself Razz when i have the money for mental price lids it goes on arai .
my duchini has so far been as good as the expensive lids i have owned however and has a higher safety rateing ....go figure Neutral
2014 Aprillia dorsoduro 750 factory.
neil.
PostPosted: 05:31 - 11 Apr 2012    Post subject: Reply with quote
When I wore contact lenses, I had a pinlock but I remember how easy it was to scratch and when refitting, how difficult it was to seat properly and make a good seal - would often get moisture building up between it and the visor. When it worked, it was great.
Now I've gone back to wearing glasses so a pinlock is useless. I've got a foggy mask and that does quite a good job. I guess I'm one of the lucky ones with the 'right' shaped face. I find it quite comfy and it fits well.
defblade
PostPosted: 05:49 - 11 Apr 2012    Post subject: Reply with quote
I've voted other:
My Suomy Vandal's visor is simply anti-fogged on the back without all this fussing about with inserts. And cheaper than visor+pinlock.
My Shoei Qwest with pinlock is just not as good at staying clear and the insert picks up scratches too easily with even the gentlest of cleaning. And when it does steam up between the 2, it's a lot harder than just opening the visor a crack to clear.
I really don't understand why all visors aren't like the Vandal's.
Mr_Cynical
PostPosted: 05:58 - 11 Apr 2012    Post subject: Reply with quote
I use a Foggy mask, but that's mostly due to the fact its my glasses that steam up way more than the visor.
Like neil, I find the foggy comfy, but it did take a lot of fannying about to fit it to my Shoei Hornet...
Bikes: '05 Better BT125-20 => '79 Honda CB750KZ (Now a project bike) => '99 Suzuki Bandit 600 => '01 Triumph Tiger 955i
"What's my motto? I like ham."
"It's a good motto, sir."
iooi
PostPosted: 07:30 - 11 Apr 2012    Post subject: Reply with quote
Voted for pin lock as the one I have now on my Nolan works a treat.
Just the glasses that mist up Rolling Eyes
But either way there is no way to stop a visor steaming up as its just never going to happen with warm mosit air on the inside and cold air on the outside....
So crack visor open a few m/m and all is fine.
Skudd
PostPosted: 09:34 - 11 Apr 2012    Post subject: Reply with quote
Pin Lock and foggy mask.
PostPosted: 10:09 - 11 Apr 2012    Post subject: Reply with quote
Fog City stick-on worked for me, a (very) slightly cheaper no-name knock off didn't. Correct fitting is vital though, it has to follow the curve of the visor tightly or you get nasty visual artifacts
snikks
PostPosted: 10:14 - 11 Apr 2012    Post subject: Reply with quote
I found the pinlock when it worked, worked well. But had issues when not sealed properly, and getting a perfect seal seemed to be difficult, and touchy (it would de-seal as soon as I opened the visor).
Have switched to a foggy mask and found it works very well - a bit of fiddling about with the placement was necessary at first to get a reasonably tight fit against my face, but since then it's "just worked" and continues to "just work" if have sunglasses inside the lid, which a pinlock didn't.
If I start to have issues when it's very cold, I may put the pinlock back in (as the posts are still there) and see how it works in tandem with the mask, but so far have seen no need.
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
TH427
PostPosted: 10:17 - 11 Apr 2012    Post subject: Reply with quote
I find foggy masks to be great when they are fitted in the right position, although this can take some trial and error, stops misting completely and keeps more heat in the helmet.
However they don't work so well with some liners as they dont stick so when you pull your head out it comes of and leaves velcro scratches on your face! Works brilliantly with my AGV though.
2000 Suzuki GN125 (Sold) - 1989 Kawasaki GPZ600R (Sold) - 2010 Yamaha XJ6N (Sold) - 2004 Triumph Daytona 600 (Sold) - 1994 GSXR750 Cafe Racer
MaryPaul This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
ws4936
PostPosted: 08:43 - 12 Apr 2012    Post subject: Reply with quote
Pinlock here. Works pretty good, so ordered another for dark visor, as that steamed up like a beach on my first exhale.
Put new pinlock insert in dark visor, again - everything is sweet. Helmet is a Nolan and the insert has a silicone beading seal. Thumbs Up
Definitely recommend.
If everything seems under control, you're just not going fast enough.
bunglehaze
PostPosted: 08:58 - 12 Apr 2012    Post subject: Reply with quote
Depending on which of my lids I decide to wear, either Pinlock or Foggy. Both work well TBH. Pinlock can get in the way of your vision very occasionally, foggy sits on your face slightly so both have minor irritations if you are that way inclined.
Personally, if I can see out of my visor and breathing in winter doesnt cause a massive mist up, I am happy.
https://bikechatter.net
Motorcycle Products Reviews and News
06 - ZZR600 > 07 - ZX6R J1 > 08 - ZX6R J2 > 09 - ZX636 A1P > 11 - ZX10R C1H
PostPosted: 09:02 - 12 Apr 2012    Post subject: Reply with quote
Pinlock FTW
pits
PostPosted: 09:21 - 12 Apr 2012    Post subject: Reply with quote
Fog City stick on things, mine is called Caberg Hypersheild or something by Fog City, 2 yeas so far hasn't misted up once, and it isn't a faff to fit, just peel and stick.
Thumbs Up Thumbs Up Thumbs Up
ceekay
PostPosted: 09:33 - 12 Apr 2012    Post subject: Reply with quote
Voted Other as my HJC FS11 visor is anti fog and it works wonderfully.
Will however be getting a darker pinlock insert though.
Yamaha YBR 125
The last post was made 13 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.61 - MySQL Queries: 16 - Page Size: 132.81 Kb
