ZX9R C1 - A whoopsy.
garth
PostPosted: 16:30 - 28 Feb 2012    Post subject: ZX9R C1 - A whoopsy. Reply with quote
Well as the title suggests I had a whoopsie.
Gearbox is what you might call, er, fucked, so last weekend it went from this:
https://oi44.tinypic.com/js0uvk.jpg
to this
https://oi44.tinypic.com/j990s9.jpg
to this
https://oi40.tinypic.com/jfkbk7.jpg
More to come, including brakes / wheels / tyres / braided lines / 12R shock / BMC Filter / Plugs / Chainguard....
and ofcourse a 03-06 Z1000 gearbox. Smile
PostPosted: 17:08 - 28 Feb 2012    Post subject: Reply with quote
Loving your work. Thumbs Up
garth
PostPosted: 11:23 - 06 Mar 2012    Post subject: Reply with quote
Well the zed box is now in. Here's the difference in the shafts.
https://i44.tinypic.com/2r3y0es.jpg
And here's my old selector fork;
https://i43.tinypic.com/dnhlww.jpg
Just got to decide whether to change the 9R Drum for the Z1000 one, and waiting on my refurb 4 pots to come. Then it's wheels out, powedercoat time, set of tyres, fit the new shock, piss off to Europe.
mad4it028
PostPosted: 12:22 - 06 Mar 2012    Post subject: Reply with quote
ive done this job lots of times now personly dont see the point in fitting the z1000 box for the sake of a selctor fork yes replace the fork it will go again but in how many miles 30000? so one change will take the bike to 60k
pluse once the engines out its half hour to change the fork 1 hour tops
garth
PostPosted: 12:34 - 06 Mar 2012    Post subject: Reply with quote
It's not just the selector fork that goes, it's the bad design of the dogs that cause it to slip out of gear. You'll never cure that without changing the gears.
Mine was wankered by 14,000.
If I'm taking the engine out, I may as well do it properly. Peace of mind.
garth
PostPosted: 08:34 - 27 Mar 2012    Post subject: Reply with quote
Quick update, I've got the engine back in and after many hours of swearing I've ridden it.
All works well, no more gearbox issues. Cool
temeluchus
PostPosted: 15:35 - 27 Mar 2012    Post subject: Reply with quote
Which gears were giving you grief?
garth
PostPosted: 15:44 - 27 Mar 2012    Post subject: Reply with quote
Fourth.
Would slip in and out, was getting steadily worse. Very un-nerving to lose drive mid corner at 100mph, it'd be like you'd whipped the clutch in for a second.
delvey91
PostPosted: 18:24 - 27 Mar 2012    Post subject: Reply with quote
My zx6 g2 used to do that in 3rd and 4th and ended up just being the clutch?
2016 Honda Africa Twin
2006 KTM 200 EXC
garth
PostPosted: 19:39 - 27 Mar 2012    Post subject: Reply with quote
Zx9r C models are known for gearbox problems.
The clutch is fine!
garth
PostPosted: 10:45 - 10 Apr 2012    Post subject: Reply with quote
All done now.
Doesn't look alot different, but I've done lots to it.
ZX12r Shock
Braided lines
Nissin 4 pots
New pads
BMC filter
Z1000 Gearbox
Scottoiler
Powdercoated wheels
Roadsmarts
And I cleaned it for the first time. Laughing
https://oi44.tinypic.com/24cwjmp.jpg
Poseidon
PostPosted: 11:15 - 10 Apr 2012    Post subject: Reply with quote
Got rid of the blue wheels eh? They look good in black! If/when I decide to do something about the flaking blue paint on my 9Rs wheels, I may go black too. I'm intrigued to see what white would look like though Thinking
1977 Honda CG125
garth
PostPosted: 11:21 - 10 Apr 2012    Post subject: Reply with quote
I had a GSXR1000 with white wheels.
Never again. Ever.
Poseidon
PostPosted: 11:30 - 10 Apr 2012    Post subject: Reply with quote
Fair point! I just imagined that putting white wheels on the 9R would have the same effect as putting white stilettos on an essex lass... i.e make them look cheap and dirty (in the good way). I hadn't considered the fact that in reality they would look like the bad kind of cheap and dirty.
1977 Honda CG125
chillyman0
PostPosted: 16:52 - 10 Apr 2012    Post subject: Reply with quote
Looks nice.
Cant wait to get through my current BT014's so I can put some roadsmarts on, love those tyres!
Just cant get on with the 14's for some reason, need to set up suspension to suit my lump really.
1996 gsf600n (sold)
garth
PostPosted: 07:41 - 11 Apr 2012    Post subject: Reply with quote
chillyman0 wrote:
Looks nice.
BT014's are wank.
Suspension set up is my job for this weekend, the rear is a bit hard and rebounds a bit quick at the moment. Front feels ok.
Probably balance the carbs too. Thumbs Up
chillyman0
PostPosted: 10:32 - 11 Apr 2012    Post subject: Reply with quote
Yeah I just cant seem to get the sus to feel right, need someone who knows what they are doing really.
And mine is also in desparate need of a carb setup, doesnt run very well and the over-run seems to choke it, dont have a set of vacs though Sad or the time Sad or the money Sad oh well dissertation is due in a week, then I may get my life back Smile
1996 gsf600n (sold)
garth
PostPosted: 11:23 - 11 Apr 2012    Post subject: Reply with quote
Have you followed the PB suspension guide? Mines much better with a longer shock in, though I think I might drop the forks through a little bit. You really do need to hang off for it to corner well though. I'll update after the weekend, it doesn't handle badly now, but can get a lot better I'm sure.
The carbs are a bastard to sync on these due to the location of the threaded holes on cylinders 2 and 3. I replaced these bolts with take off stubs whilst my engine was out.
chillyman0
PostPosted: 14:12 - 11 Apr 2012    Post subject: Reply with quote
I dont know if Ive seen that guide...
I have done the basic setup of static sag, rider sag and put the compression/rebound settings back to near stock as a basis to go from but everything still feels really wooden and I have no confidence in corners, was thinking that the rear shock may be set too hard, but its pretty much stock and Im a fat bastard...
Dunno, I'll probs pay someone to do it properly when I have the money!
1996 gsf600n (sold)
garth
PostPosted: 08:13 - 23 Apr 2012    Post subject: Reply with quote
If anyone is interested in this, pm me.
evoboy
PostPosted: 12:27 - 23 Apr 2012    Post subject: Reply with quote
the zx12 shock is longer? You can adjust the rear ride height with the bolt adjuster on the top of the shock. Newer zx6 shocks fit aswel.
APT Motorcycles
garth
PostPosted: 12:50 - 23 Apr 2012    Post subject: Reply with quote
C1 shocks are rubbish, the 12R is the same length as the later bikes, with finer adjustment. Thumbs Up
Wave2k
G's Stalker
PostPosted: 15:57 - 23 Apr 2012    Post subject: Reply with quote
Wow, i would never be able to do this.
Ducati 1299 Panigale
2009 Corvette C6 z51
The last post was made 14 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.25 - MySQL Queries: 14 - Page Size: 120.56 Kb
