dave_bole |
dave_bole Borekit Bruiser
Noxious89123 |
Noxious89123 World Chat Champion
Posted: 22:57 - 07 May 2012 Post subject: |
A new plug is worth a try; Cheap and easy. Is th HT lead in good condition? Is the plug wet when you take it out after cranking it over? ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
dave_bole |
Efes123 |
Efes123 World Chat Champion
P. |
P. Red Rocket
dave_bole |
P. |
P. Red Rocket
dave_bole |
Budgetboy |
Budgetboy Scooby Slapper
Posted: 20:23 - 08 May 2012 Post subject: |
First make sure you have a good (BLUE) spark from the plug.
make sure your air filter is clean..
Then make sure the fuel is getting to the carb.
Take off the carb and clean the idle(pilot) jet and main jet.
Refit and try to start.
Fuel/Spark/Air are 3 of the things you need to make the engine run.. The 4th being Compression.
You need at least 100psi of compression to make an engine run (not inc things like outboards,mowers etc) ____________________ www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken. |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 20:35 - 08 May 2012 Post subject: |
The symptoms when it spluttered to a halt SOUND like running out of petrol....
So start there.... ask the stoopid and obviouse FIRST.
- DID you have petrol in it?
- Did you stwitch to reserve?
No... OK... JUST CHECKING......
So you have fuel, is it getting to carbs... breathers dont suddenly kink... but 'sludge' in bottom of tank does swill up and clock the strainer, or the tap or the sediment bowl, or the fuel pipe, or the float needle port, or the jets....
Thats the list working down from the tank to where it gets into the engine, so worth through checking each link in the chain in turn, eliminating the possibility.
Once you are sure that the carb is getting fuel, and carb is delivering fuel to air-stream into the engine....
THEN come back and we can discuss, low compression, tappet clearances, piston rings, Head-Gasket failure or myriad other possible faults that much further down the fault-tree! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
dave_bole |
P. |
P. Red Rocket
dave_bole |
P. |
P. Red Rocket
dave_bole |
The last post was made 11 years, 353 days ago. Instead of replying here, would creating a new thread be more useful? |
