KevTM |
 KevTM World Chat Champion
 Posted: 21:09 - 26 Apr 2004 Post subject: NS125R hesitation around 3k - 5k revs |
Went out on my bike for the first time to day and enjoyed it very much.. got a nice powerband
Only thing is though it hesitates around 3k - 5k revs. Usually dipping the clutch and letting it out again whilst keeping revs around 6k - 7k will do the trick. Any ideas on what the problem is?
It wouldn't bother me too much but it's a pain in the ass trying yo get to 30mph - 40mph without revving the bollox off it.
Cheers. |
Ian (GPX) |
 Ian (GPX) Brolly Dolly
KevTM |
 Posted: 23:10 - 26 Apr 2004 Post subject: |
Ok. It just seems to be quite mince around the lower revs compared to my other 2-strokes that i've had (if i remember correctly).
I'll live with it! it just means i need to feather the clutch to keep the revs a little higher.. cheers!  |
G |
 G The Voice of Reason
 Posted: 23:18 - 26 Apr 2004 Post subject: |
Have you had another (road) sports 2 stroke?
They aint designed to be ridden below 5k rpm .. rev the bollocks off it ... that's what it was designed for .
Fiddling with the carb may well sort something... but the only time I took an NS carb apart I think I made it even worse. |
AcIdBuRnZ |
 AcIdBuRnZ World Chat Champion
KevTM |
 Posted: 00:06 - 28 Apr 2004 Post subject: |
no problems. i was just curious in case i had some sort of problem which may have gotten worse, or could have been easily sorted.
It's running great and the hesitation is more or less between 4.5k and 5k. Anyway, atleast i know it's alright!
thanks. |
Kickstart |
 Kickstart The Oracle
jimbo |
 jimbo Borekit Bruiser
 Posted: 14:21 - 29 Apr 2004 Post subject: |
Kickstart wrote: | The trouble with this is that at half those revs the pressure waves are doing their best to shove those exhaust gases back in to the engine, causing a flat spot. |
The reality is that the same pressure wave interference is happening anywhere outside the power band. So the power valve was invented in the 1980s to address the problem.
The power valve evens out the power curve by reducing the exhaust port area at low revs, reducing the effect of non-resonant pressure waves from the exhaust.
The flat spot on the NSR coincides with the point where the power valve starts to open. If you watch the servo while you rev the engine (warmed up of course), you'll see it tweak the valve just after your flat-spot. (the servo operates twice, around 2k and then between 5k and 7k depending on your set-up). The flat spot is the result of the cross-over region between low-rev range and high-rev range power valve settings. At this point the end of the low-range curve and the start of the high-range curve coincide, giving the worst of both worlds and a boggy patch.
The most interesting feature of exhaust-pipe tuning is not the removal of the exhaust by the pressure wave, but the compression of the mixture in the cylinder by a pressure wave node. At peak power, the pressure wave pulls unburnt mixture into the exhaust throat, and then pushes it back into the cylinder. This is like a turbo, increasing the compression and allowing tuned 125 2-strokes to burn more than their rated capacity. Some say up to an equivalent 180cc of fuel is burnt at resonance, but i don't know how that can be measured. This is one of the reasons why 2-strokes burn more fuel than 4-strokes.
The flat spot on my NSR is at 6.5-7k, which is ideal because it happily motors up to 60mph before the power valve opens. This means i can drive like a granny, save fuel and still make reasonable progress, or kick it down a gear and get into the power band. |
Kickstart |
jimbo |
coolfox1 |
 coolfox1 Scooby Slapper
The last post was made 21 years, 103 days ago. Instead of replying here, would creating a new thread be more useful? |
