| Author |
| TamaJosh |
 TamaJosh Nova Slayer
| Back to top |
| Pete. |
 Pete. Super Spammer
 Posted: 17:38 - 03 Jun 2012 Post subject: |
2 years in a garage is nothing. Check the oil level, fit a new battery and start it up.
You'll be needing a new battery so you might as well get one right away. ____________________ a.k.a 'Geri'
| Back to top |
| Ronin |
 Ronin Nova Slayer
 Posted: 17:43 - 03 Jun 2012 Post subject: |
I would remove the spark plugs and clean them.Also while they are out crank the engine over until the oil light goes out just give the engine a coat of oil before it starts.and that is it .Once you have got it running give it a service and you should be good to go.  |
| Back to top |
| MaybeGuy |
 MaybeGuy Super Spammer
| Back to top |
| TamaJosh |
| Back to top |
| Vincent |
 Vincent Banned
| Back to top |
| TamaJosh |
| Back to top |
| MaybeGuy |
| Back to top |
| Vincent |
 Vincent Banned
 Posted: 20:30 - 04 Jun 2012 Post subject: |
Make sure you post some pics  ____________________ Space Is Deep |
| Back to top |
| Vincent |
 Vincent Banned
| Back to top |
| Vincent |
 Vincent Banned
 Posted: 20:39 - 04 Jun 2012 Post subject: |
Blimey, this bike has a bit of an identity crises - ZZR250, ZX250, GPX250, EX250, GPZ250 Ninja 250R, any more?  ____________________ Space Is Deep |
| Back to top |
| TamaJosh |
| Back to top |
| Vincent |
 Vincent Banned
| Back to top |
| andym |
 andym World Chat Champion
| Back to top |
| TamaJosh |
| Back to top |
| Vincent |
 Vincent Banned
 Posted: 21:24 - 04 Jun 2012 Post subject: |
Good find  ____________________ Space Is Deep |
| Back to top |
| TamaJosh |
| Back to top |
| Microcut |
 Microcut Renault 5 Driver
 Posted: 09:34 - 05 Jun 2012 Post subject: |
So would you say, if fresh oil was put into a bike about 3 yrs ago and never if ever used in that time, you wouldn't necessarily need to change the oil if using the bike now?
.what happens to oil over a long period of time when sat?
It's all interesting to me atm  |
| Back to top |
| Robby |
 Robby Dirty Old Man
 Posted: 10:16 - 05 Jun 2012 Post subject: |
As said, just start it. You should change the oil and give it a check over after riding it home, and it will probably need a new battery, but don't go crazy trying to fix problems that might not exist.
The oil should be changed simply because it has been in there a long time, but it should have another oil change at the end of the break-in period anyway (500 or 1000 miles). The battery may be ok if you get lucky - leave it on an optimate or similar overnight, might save it.
Don't worry about stuff like cranking it with the plugs out to get the oil circulating, the oil takes about two seconds to get around the engine and it will be sitting on tickover anyway, so no problems there.
Check the tyre pressures before riding, make sure the lights work, and pump the suspension a few times.
Two years in a garage is nothing, and any problems that have accumulated will mostly be fixed by riding it. |
| Back to top |
| TamaJosh |
 Posted: 20:57 - 05 Jun 2012 Post subject: |
Right guys, back now!
The XT battery worked ok, it had to try a little to start the bike ( like 5 seconds if turning before a start) probably down to having 10A less than than the bike demands and the bike starting for the first time after a while. Fits in ok if you reposition the ECU. No warning lights or anything, didn't actually check sparks or crank the engine because the fairings would have been a pig to remove. The bike rides perfectly, doesn't break a sweat even below the powerband (which I'm avoiding until its broken in more) and barely heats up.
Very pleased with it, did around 70 miles on the way home and each one was enjoyable. The battery is on an optimate and already says its getting better. Would reccomend this bike to anyone, to Hell with next year's restriction changes, this thing is fun!
A few pics on here as requested, on my mobile so I couldn't copy the embed codes easily.
https://s1162.photobucket.com/albums/q524/JoshHF/ |
| Back to top |
The last post was made 14 years, 161 days ago. Instead of replying here, would creating a new thread be more useful? |
