seriving Kawasaki ZZR250
tatters
Exxon Valdez
PostPosted: 23:51 - 01 May 2004    Post subject: seriving Kawasaki ZZR250 Reply with quote
just got a zzr250, and it needs a serivice does any one know which oil is best for it, what to check for on the bike and what l need to do to service it. (serviced 2 strokes before but never had a 4 stroke).
PostPosted: 11:06 - 02 May 2004    Post subject: Reply with quote
Which oil to use is a "how long is a piece of string" question. I often use car oil to be honest in bikes used for commuting and the like. However for a bike that is being pushed hard then just go for a half decent semi synthetic bike oil.
Change the oil filter as well.
Check the air filter and maybe clean that.
Maybe remove and clean the filter going to the carb heaters.
Check valve clearances
Balance carbs.
Check all the bearings (ie, wheel bearings, steering head bearings, swinging arm bearings).
Do these, or at least some of them. Carbs rarely go out of balance unless you have done work to the engine. Valve clearances tend to be fine for quite a while. Basically do all these on a full service, but a few less on a normal service.
The last post was made 21 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 32.39 Kb
