Battery goes flat when it rains
J.M.
PostPosted: 09:18 - 11 Jun 2012    Post subject: Battery goes flat when it rains Reply with quote
So I've had this bike for a while now and I usually have no troubles starting it. I usually keep it in a dry place where the rain doesn't get to it.
I've noticed that it sometimes runs out of battery though and the common thing throughout this seems to be the rain.
For instance, I went over to my girlfriends once who is 160 miles away a while ago. The bike started a treat before I left. I rode the entire way there only stopping at one petrol station about 140 miles in. Bike started lovely after filling up (which it should as the engine is still hot) and I finished off the rest of the journey.
Once at hers, it started raining for the entire weekend. On the Sunday evening, I attempt to leave (arrived Saturday afternoon) and the bike won't start. The battery is flat. I managed to bump start it and away I went. From there on there was plenty of charge in the battery to let me start the bike effortlessly when stopping at petrol stations and service stations.
So that rules out an alternator fault because the battery is being charged.
It's also happened again today. I'm supposed to be at college right now but instead I'm sitting here typing this whilst the battery is on charge.
Last night I went out for a ride. Battery was a little bit flat but just enough to start the engine. I did about 40 miles without stopping, just thankful to finally be out and about on my bike again. I got home and couldn't be bothered to put the bike away. I was tired and my shed was a complete mess, so I would have to tidy up first.
I just left it on the driveway.
It's been raining this morning. Not excessively heavily, but trying to start the bike just didn't work. Flat battery again.
This never seems to happen when the bike has been left in the dry. It only seems to happen when the bike has been left out in the rain.
Any ideas why? I'm stumped.
I don't think it's the battery because it's been kept off the road for a month whilst I fixed it and it started perfectly going out on it last night. So the battery holds charge alright.
My usual commute is 10 miles and I always seem to have a fully charged battery at both ends. At college the bike is kept under a shelter where it's pretty dry.
2004 R1 & 2018 XSR900
PostPosted: 09:25 - 11 Jun 2012    Post subject: Reply with quote
Not big on bike repairs but first thing I would do is check your wiring, especially around the connections, lights, fusebox ect. Possibly the rain creating a circuit between the positive and negative connections and draining the battery.
J.M.
PostPosted: 10:08 - 11 Jun 2012    Post subject: Reply with quote
Could a connection between the positive terminal on the battery and the frame cause this?
If so it could be the heated grips that the previous owner installed. I'll wrap some electrical tape around that connector now to be safe.
map
Mr Calendar
PostPosted: 10:16 - 11 Jun 2012    Post subject: Reply with quote
Suspect a leak to earth. Check the earth strap and earth connection from the battery to frame. One I had recently looked ok but just crumpled to dust when actually felt.
Other than that it maybe a short in the wiring leaking to earth when damp or indeed the extra heated grips (check any switch in circuit).
HTH Thumbs Up
mysterious_rider
Ah this is what happened on my bike. Just fitting oxford heated grips without a switch drained my battery completely.
PostPosted: 10:17 - 11 Jun 2012    Post subject: Reply with quote
Absolutely. Most modern bikes are negative earth, so if a positive wire has an electrical connection with the frame then it will earth causing a short circuit and then a flat battery. This is very very bad for the battery and could cause it to heat up, or cause a spark. You should absolutely make sure that any positive wires which go near any metalwork on the bike are sufficiently insulated.
J.M.
PostPosted: 11:16 - 11 Jun 2012    Post subject: Reply with quote
I've just been out to the bike with an umbrella and wrapped the suspect connections connecting to the battery with electrical tape, leaving enough to still connect them to the battery though.
The heated grips (+) 12v to the relay had a about 5mm of exposed wire where the previous owner had obviously stripped too much of the wire when attaching it to the circular terminal to the battery. This wire (and exposed part) ran extremely close to the frame, so with moist I suspect that a circuit could be created between that and the frame. Though the wires all looked and felt dry when I removed the seat earlier.
Do you know where to find the earth on a GS500?
The previous owner installed the heated grips through a relay though, coming off of the switched live, so this shouldn't theoretically be an issue.
Though, saying that, Paddy and MrJoolz did have to bump start me one morning after leaving the heated grips on. The lights on the control box were all off because the ignition was off, but I did leave it "on". I also left them on at the girlfriends that night that I ran out of battery.
Last night they weren't even plugged in though. I think I forgot to reconnect the (-) wire when assembling the bike. I couldn't even get them to turn on.
Right, okay, thanks.
I did actually knock part of an exposed wire (that I hadn't noticed... previous owner again...) against the frame and thought I had set the bloody bike on fire. That part of exposed wire obviously got insulated with electrical tape.
I'm thinking that these heated grips need to be removed and installed again, properly. I just presumed because they used a relay that they knew what they were doing. I'm beginning to doubt that judgement though.
Battery is sitting on about 12.5v now. Unsure whether I should try it now or wait until it has more charge. A good 12v battery not under load should read about 14v with the multimeter right? Either way, may as well stay at home for a while and have a decent lunch then try the battery afterwards.
PostPosted: 14:25 - 11 Jun 2012    Post subject: Reply with quote
IIRC your lights come on with the ON ignition position.
Try starting straight away to prevent draining, I've started the bandit on 12.1v when I got the new battery. It started ok...bit slow on the starter though.
LOL at bump start, in damp, before IOW ferry. Fun Laughing
J.M.
PostPosted: 14:50 - 11 Jun 2012    Post subject: Reply with quote
Yep, they do.
If I use the Cyclone's electric start though, that seems to be better at starting the bike on low battery than using the starter button itself. Just don't have the Cyclone connected at the moment so it wasn't really an option.
I hate the GS when it's cold. It's a right pain to start. Had about 12.5v in the battery and tried to start it. Almost got there but the battery gave up before then.
I just gave up in the end now. Battery is on charge in my room. I'll leave it on charge overnight and fire her up in the morning. Successfully, I hope.
Yeah, that was an interesting start to the morning Laughing See what I mean though. It started perfectly the rest of the day and the day after. Thinking
The last post was made 14 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 68.37 Kb
