Red lights not recognising bikes
Benno
PostPosted: 14:29 - 10 Jun 2012    Post subject: Red lights not recognising bikes Reply with quote
There is a junction near me with a red light that STAYS red if it is only me sitting by it on my bike.
Yesterday I got fed up with waiting, it was nearly deserted, so I waited until the lights on the road next to mine went green (it's a multi-road junction) and followed out the only car coming from that road, going through my red light.
What should you do in such a situation? It's not the only set of lights I've encountered that stay red on bikes. Also - paranoid question - is there any chance that they could have got my number plate from some crazy big brother tech out there?
The junction:
https://maps.google.com/maps?q=university+of+reading&hl=en&ll=51.442727,-0.954107&spn=0.000975,0.002411&sll=37.0625,-95.677068&sspn=40.460237,79.013672&t=h&hnear=University+Of+Reading,+Reading+RG6+6AQ,+United+Kingdom&z=19&layer=c&cbll=51.442854,-0.954294&panoid=ZQygoeF8weZOvTWrX1rQ8A&cbp=12,233.48,,0,12.31
anthony_r6
PostPosted: 14:34 - 10 Jun 2012    Post subject: Reply with quote
Is there not a sensor buried into the road? Have a look around next time your there. I don't think flashing it is going to help as it doesn't have those little cameras on the top.
Benno
PostPosted: 14:36 - 10 Jun 2012    Post subject: Reply with quote
I've looked around, I can't see any sensors. The road is plain tarmac and there are no sensors on top of the lights so I have no idea why they stay red unless there is some other detection device hidden somewhere.
ElliotReidMD
PostPosted: 14:37 - 10 Jun 2012    Post subject: Reply with quote
Some people attach neodymium magnets to the bottom of their bikes to increase the magnetic signature and activate these induction loop lights. No idea if it works but I've seen one video that indicates it does.
Current Bike: Kawasaki Versys
Beelzebob
PostPosted: 14:49 - 10 Jun 2012    Post subject: Reply with quote
Likely that, as has been said, the sensors are in the road but set up to pick up the signature of a car or larger. There was a junction like that near the bike instructors I used back in 2010, and they mentioned it. Something to do with not having a big enough lump of metal between your legs.
In the circumstances I would say you've got a pretty solid argument for just treating it as you did - proceed with caution. That's exactly the same as you would do if the lights weren't working at all. As long as you're aware of what the other lights are doing (to a degree) so that you don't surprise anyone that's going through a green light then you should be ok.
'09 YBR 125 -> '92 XJ600 S Diversion -> '99 Hornet 600
"Stronger than your average female lifeguard"
PostPosted: 15:09 - 10 Jun 2012    Post subject: Reply with quote
We've a set up the road from where I live that wont pick bikes up. Oddly enough the next set down are fine and work like a charm but I have been known to stop for ages waiting for a car to come along and trip the lights.
On a Sunday night/Monday morning I tend to take the longer way home just to avoid these horrid lights as there are very few cars on the road when I am coming home from work.
mysterious_rider
PostPosted: 15:21 - 10 Jun 2012    Post subject: Reply with quote
Ones near me dont work properly with bikes so I don't even wait anymore. Just see if its clear and run em' Laughing
edit; I should mention this is about 3am when there's pretty much no traffic about.
shereen
PostPosted: 15:24 - 10 Jun 2012    Post subject: Reply with quote
There was a thing I read somewhere about this. Basically the law/highwaycode states that you should wait an appropriate amount of time before going through the lights. It advises you should proceed with caution.
I will try and find it
map
Mr Calendar
PostPosted: 15:26 - 10 Jun 2012    Post subject: Reply with quote
Our work security gate opens when cars approach to go out (key entry in!). So far the bikes haven't triggered it and I've been lucky to time my ride out with either someone coming in or out.
I have been meaning to try the magnet solution. I think an alternative name is 'rare earth' magnets.
On topic I'd go with the solution above and treat the lights as faulty. Genuine case happened to me once in the car late one night. Tried running backwards and forwards over the sensor with no joy. Police car came up behind me and did the same. Eventually told by the officer to just proceed with caution across the junction.
PostPosted: 16:00 - 10 Jun 2012    Post subject: Reply with quote
Report a traffic light fault.
Also, pfft, traffic lights are just advisory (IMO, I know what the law says), red just means somebody else thinks they've got right of way.
miss.metallica
PostPosted: 16:02 - 10 Jun 2012    Post subject: Reply with quote
Theres also one of these lights by me, i make sure i swerve about a bit before i stop make sure its picked me up. Highly embarrassing when you have to move over & ask the guy in the car behind you to pull up so that huge trail of traffic behind can get moving Laughing
LordShaftesbu...
PostPosted: 16:18 - 10 Jun 2012    Post subject: Reply with quote
If this type of lights don't work for motorcycles, presumably whoever decided to install them knew with certainty that they wouldn't turn green for bicycles. I wonder what justification they gave?
This seems eminently reasonable to me, seeing as the lights were indeed not working properly (the fact that this is by design is irrelevant).
Fizzer Thou
PostPosted: 16:30 - 10 Jun 2012    Post subject: Reply with quote
I remember reading about this situation elsewhere.If you contact the local councils highways department they can adjust the sensitivity of the induction loop set into the road.
Look for 'V' shapes lines in the road which pick up the speed of vehicles approaching the lights as well as square shape lines which pick up the vehicle standing at the stop line.
Always have a 'Plan B'
Derivative
PostPosted: 17:06 - 10 Jun 2012    Post subject: Re: Red lights not recognising bikes Reply with quote
The junction:
There's a roundabout near me that wouldn't let me though on my bicycle. I just ended up getting off and walking it on the path, I don't fancy taking my chances at night.
Near the out of town Tesco in Oxford.
Benno
PostPosted: 17:08 - 10 Jun 2012    Post subject: Reply with quote
Thanks for that, reported it to the council.
That would be very useful if you could!
I got stuck at some traffic lights leading onto Oxpens Road (I think that's the name of FH's road?). I need to find another route to FH.
I suppose if you are ever truly stuck on a motorbike you could just wheel it over the pavement...
yen_powell
PostPosted: 17:29 - 10 Jun 2012    Post subject: Reply with quote
I used to lay traffic sensing loops on the roads (for traffic counts rather than signals). Loops are more sensitive at their corners. Look for the slots cut into the carriageway then make sure to ride your bike over one of the the corners rather than through the middle of a straight part.
We've got a rising barrier at work that won't recognise a motorcycle unless you do the same, the cyclists have even sprayed a mark for the best position to pick them up.
XT1200Z and a DR350 in bits
brythered92
PostPosted: 18:05 - 10 Jun 2012    Post subject: Reply with quote
eastern road near sainsburys ? they take forever and i often go through them... or in northend turning right to hein gerik is terrible
r6 99 quill pipe ....
kawakid
PostPosted: 22:03 - 10 Jun 2012    Post subject: Reply with quote
One near my work, which is from an industrial estate to a T junction, doesn't detect motorcycles at all. During the week it's not normally a problem a car always comes.
On a weekend I have to get off my bike, push it on to the pavement and walk it round. Absolute crayp system.
I've a twin and a 4.
MinhDinh
PostPosted: 22:15 - 10 Jun 2012    Post subject: Reply with quote
Usually staying back a car distance works, and flashing if there is a camera type sensor. However if it doesn't work, I wait 5 mins and go invade there is a camera. Apparently lots of council cameras fine people for this.
Hit the G spot. Wink
Slacker24seve...
PostPosted: 22:22 - 10 Jun 2012    Post subject: Reply with quote
Invade?
https://upload.wikimedia.org/wikipedia/commons/6/61/Landing_beach_on_the_opening_day_of_the_invasion_of_Sicily.jpg
Banger rallies are ace
bikertomm
PostPosted: 22:42 - 10 Jun 2012    Post subject: Reply with quote
If it's safe to go through once you're sure it doesn't recognise you I'd just go, however if there is a red light camera I'd turn around. Very Happy Thumbs Up
Old Git Racing
PostPosted: 22:54 - 10 Jun 2012    Post subject: Reply with quote
I had a similar problem with my TV, found I had forgotten to renew the TV license but found it still worked when I switched it on. Went out and got one the next day and didn't hear anything about it.
Sometimes I think we have just got to get the bull by the horns and go with it.
OGR
MinhDinh
PostPosted: 01:09 - 11 Jun 2012    Post subject: Reply with quote
Slacker24seven wrote:
Invade?
Bloody I phone auto correct!
snikks
PostPosted: 11:16 - 11 Jun 2012    Post subject: Reply with quote
I was under the impression that technically, malfunctioning traffic lights do not comply with the appropriate traffic regulations, and therefore you'd have a reasonable defence for going through them with due caution should you get prosecuted.
I suspect what this means in practice is that if it is abundantly clear the lights are not working, nobody would bother to prosecute anyway, but a good way to CYA would probably be to report them as faulty asap.
Portable traffic lights, I think, are supposed to have a circuit that automatically generates a demand for passage every 2.5 minutes, which is specifically to cover the circumstance of a motorcycle or bicycle not registering.
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
tbourner
PostPosted: 11:25 - 11 Jun 2012    Post subject: Reply with quote
There is a sensor but it's not at the white line which is odd (diagonal shiny tarmac about 2 car lengths back):
https://maps.google.com/maps?q=university+of+reading&hl=en&ll=51.442854,-0.953785&spn=0.001037,0.002194&sll=37.0625,-95.677068&sspn=40.460237,79.013672&t=h&hnear=University+Of+Reading,+Reading+RG6+6AQ,+United+Kingdom&layer=c&cbll=51.442784,-0.954485&panoid=NlTztN56FfXg9lM3AcGVpA&cbp=12,63.25,,1,8.55&z=19
Make sure you ride over it near to the edge to get the most, or maybe swerve violently and dangerously from right to left to cover as much of it as possible Very Happy .
Trev, now a biker?
Looking for first big bike.
The last post was made 14 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.38 - MySQL Queries: 14 - Page Size: 135.77 Kb
