Home made fork seal driver - USD forks
MarkJ
PostPosted: 16:27 - 19 Jun 2012    Post subject: Home made fork seal driver - USD forks Reply with quote
Afternoon all.
I want to give my forks a full rebuild in the near future. With RWU forks you can just buy some plastic waste pipe and drive the seals in, but USD forks have the caliper brackets and spindle gubbins at the bottom of the stanchion.
Is there a DIY fork seal driver you can make for USD forks, other than tapping them in with half of an old seal and a hammer? I don't fancy spending £30-40 on a proper seal driver.
PostPosted: 18:01 - 19 Jun 2012    Post subject: Reply with quote
I put a grinder to my old seal... cut into 2 pieces but lost about 5mm each side, tapped them in using a piece of rubber and a mallet. Easier to show with photos Laughing
PostPosted: 18:14 - 19 Jun 2012    Post subject: Re: Home made fork seal driver - USD forks Reply with quote
You can still use plastic waste pipe - cut a slit down the pipe (I find it's rarely the perfect size, so do this anyway). You can then slip it over, despite the chunkier fork end.
For normal forks, I'll also often do Paddy's suggestion as well; though of course then you don't need the "cutting in half" bit.
Fizzer Thou
PostPosted: 18:27 - 19 Jun 2012    Post subject: Reply with quote
If you were anywhere near Bexleyheath I have an adjustable 35-45 and a fixed 48mm fork seal driver in the tool box.
But in the past I have visited a workshop with everything in place and asked for the seals to be driven into place.Donated £2 to the coffee tin as it took 10 seconds and the paperwork would have taken longer than the job itself.
Always have a 'Plan B'
MarkJ
PostPosted: 09:21 - 20 Jun 2012    Post subject: Reply with quote
Thanks, some good responses (apart from the spammer Laughing)
Thanks for the kind offer Fizzer but I think the petrol to get to Bexleyheath might cost as much as a driver Thumbs Up
kramdra
PostPosted: 01:21 - 21 Jun 2012    Post subject: Reply with quote
Maybe I am fail but when doing my cg125 last year, I just put the seals in before the tubes. 90% sure thats how I did it and cant see why USd should be different.
Anyone know of a guide for chinese USd forks? Sinnis stealth/quingi 125-2d
PostPosted: 09:03 - 21 Jun 2012    Post subject: Reply with quote
A few 'good' USD forks you can do this.
The vast majority of 'good' (ie not really cheap) forks you can't do this for either type - because the bushes hold the stanchion in behind the seals.
MarkJ
PostPosted: 09:12 - 21 Jun 2012    Post subject: Reply with quote
Yep, I knocked my CG seals in with a large socket before the stanchion because there are no bushes, but my Showa forks on the RSV have bushes behind the seals.
The last post was made 13 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 55.3 Kb
