Kawasaki er-5 starting problems
juice
PostPosted: 10:04 - 07 May 2004    Post subject: Kawasaki er-5 starting problems Reply with quote
Hi all.
I am a bit kak-handed when it comes to spanner work and I can barely tell a big-end from an oil sump but... my er-5 refuses to start and i've tracked the problem (i think) down to the electrics.
When I turn it over using the starter button, the starter motor turns a couple of times and then a little box connected to the electrics (located on the right hand side behind a removable fairing just to the rear of the fuel tank) emits an electrical buzzing sound as if it is shorting out and oxidised copper dust starts coming out from where I assume there are a couple of teminals at the rear of said box. I have checked and charged my battery with an Optimate and it is in tip-top shape. I am kind of at a loss and any advice would be much appreciated by myself and missus juice and the neighbours as they are sick of the blue language eminating from the garage!
Thanks in advance for your help!!
Zx6man
PostPosted: 10:30 - 07 May 2004    Post subject: Reply with quote
It does sound like a damaged battery. The optimates are a bit misleading, as they will still show its charged up good, if it can charge even one of the cells in the battery.
PostPosted: 22:35 - 07 May 2004    Post subject: Reply with quote
Sounds to me like a probably battery problem as well.
However the bit that is making the noise is the starter relay. That could also be faulty. All it does it act as an electrically operated switch. These are probably around £25.
juice
PostPosted: 09:31 - 10 May 2004    Post subject: Reply with quote
Got a new battery over the weekend and all is good again. Thanks for the replies and advice, you guys are ace.
Zx6man
PostPosted: 10:11 - 10 May 2004    Post subject: Reply with quote
No problem. Optimates are very good, I bought a new one because I thought it wasn't charging the battery right as well. Got one on each bike now tho.
The last post was made 21 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.4 - MySQL Queries: 13 - Page Size: 42.91 Kb
