HOW DO I REMOVE NSR125 ENGINE ON A 92 MODEL
 Topic moved: from General Bike Chat to The Workshop by Korn (8 May 2004 - 16:46)
novus
PostPosted: 14:55 - 08 May 2004    Post subject: HOW DO I REMOVE NSR125 ENGINE ON A 92 MODEL Reply with quote
I NEED TO CHANGE THE BARREL AND PISTON ON MY 92 MODEL HONDA NSR CAN ANTBODY HELP ME OR DIRECT ME TO AN ONLINE SERVICE MANUAL?????
LEWIS IN OXFORD
Mac
PostPosted: 14:59 - 08 May 2004    Post subject: Reply with quote
Capitals really hurt my eyes Shocked
I want a bigger bike!
PostPosted: 15:06 - 08 May 2004    Post subject: Reply with quote
You can do the top end of the engine without removing the engine from the frame.
To remove the engine from the frame you need to remove the exhaust, carb, drain the coolant and remove the radiator. Disconnect the pipe from the oil pump to the carb, and from the 2 stroke oil reservior to the engine. Disconnect the ignition wiring, the temp sensor wiring, the starter motor wiring and the cable to the oil pump. Undo the 3 bolts holding the engine in place, then hold the engine while you push the bolts out. Place engine on floor!
To be honest it is a very easy bike to remove the engine from.
novus
PostPosted: 15:12 - 08 May 2004    Post subject: Reply with quote
cheers mate should be ridin again soon
The last post was made 21 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 16 - Page Size: 40.48 Kb
