How to do away with earplugs when riding
EazyDuz
PostPosted: 21:23 - 11 Jul 2012    Post subject: How to do away with earplugs when riding Reply with quote
1. Buy some memory foam type material or similar, i bought these:
https://www.ebay.co.uk/itm/160780211693?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
2. Cut circles from them. I did two circles for each ear, tucked them into the ear moulds in the helmet. I then cut a much larger peice which tucks between the helmet inside shell and the cushioning. It doesnt fall out:
https://i605.photobucket.com/albums/tt134/Kurt_V/SV206502.jpg
Greatly reduces wind noise. Hope this helps someone
Noxious89123
PostPosted: 00:13 - 12 Jul 2012    Post subject: Reply with quote
Doesn't it squash your eas some what?
EazyDuz
PostPosted: 06:44 - 12 Jul 2012    Post subject: Reply with quote
Nope, its memory foam, it moulds around the ears.
Noxious89123
PostPosted: 22:21 - 12 Jul 2012    Post subject: Reply with quote
Yeah, but only by being squished by your ears surely!
Cunningly simple idea though, and cool if it works. I'll stick with my ear plugs though Thumbs Up
rac3r
PostPosted: 22:53 - 12 Jul 2012    Post subject: Reply with quote
Until someone brands it and sells it Wink Laughing
Chequered Flag
EazyDuz
PostPosted: 07:23 - 13 Jul 2012    Post subject: Reply with quote
To be honest i did do a long google search to find and buy a product which already does this, but there isnt one. One website sells some memory foam inserts to make the helmet more comfortable, but not around the ears.
It does press against the ears a bit, but they work more by sound deadening the helmets walls, so wind noise from outside and also coming inside the helmet dont reach your ears as much.
Peirre oBollox
PostPosted: 08:12 - 13 Jul 2012    Post subject: Reply with quote
I`m not convinced that this new method will give enough protection, especially with all the movement the helmet/head goes through during normal riding conditions ie: looking left/right. Surely these new memory foam pads will allow some leakage during normal use. But on the plus side, as opposed to earplugs which only reduce noise entering via the ear canal, memory foam may help reduce the conductive noise that can be transmitted to the inner ear via the area of flesh and bone around the ear canal
EazyDuz
PostPosted: 09:28 - 13 Jul 2012    Post subject: Reply with quote
Well my helmet is a really good fit, it just seems they skimped on padding around the ear area abit which lets it down. It was only £90 though so still budget category, but it isnt the quietest of helmets.
Looking left/right doesnt alter anything because the padding is larger than my entire ear, so even when the helmet moves slightly, the ear is still protected.
Its not as quiet as some good earplugs but i find it lets me hear enough to stay safe, i found earplugs were both annoying to put in/take out/remember to keep, and too restricting with sounds.
UnknownStuntm...
PostPosted: 10:12 - 13 Jul 2012    Post subject: Reply with quote
Nice idea, I like it.
I was kinda hoping your idea might have been a 'skirt' that clips in to the bottom of the helmet and makes more of a seal around your neck... I've noticed Arai in particular leave a massive gap and it's noisy as holy hell! There's a rubber seal around the bottom of the lid, I'm sure a skirt could be attached to this with some stretchy (neoprene?) material.
I'll buy one off you when it's done. Smile
promufa
PostPosted: 12:05 - 13 Jul 2012    Post subject: Reply with quote
That's already on the market https://www.ebay.co.uk/itm/BIKE-IT-MOTORBIKE-MOTORCYCLE-UNIVERSAL-NEOPRENE-LOWER-HELMET-SKIRT-GHOSTBIKES-/380441894517?pt=LH_DefaultDomain_3&hash=item58941a9e75
'02 Triumph Speed Four
EazyDuz
PostPosted: 14:00 - 13 Jul 2012    Post subject: Reply with quote
if any of you steal my idea i'll kill you, now to contact Dragons Den
goto10
PostPosted: 15:56 - 13 Jul 2012    Post subject: Reply with quote
My Shoei came with a removable neck skirt.
iooi
PostPosted: 12:57 - 14 Jul 2012    Post subject: Reply with quote
If the helmet is moving on your head while looking left/right... Then your helmet is not a good fit and you need to get a new one.
Think of it hitting the floor, its going to twist on your head Shocked
Walloper
PostPosted: 18:44 - 14 Jul 2012    Post subject: Reply with quote
This is shite.
Have you tested your 'invention' to measure, by a recognised standard, what noise it blocks?
I guess not.
I assume you tried it on your noggin and the sound 'you' heard was reduced.
In 'your' opinion this 'is as good as proper earplugs'.
I say, 'is it fcuk.'
multijoy
PostPosted: 19:29 - 14 Jul 2012    Post subject: Reply with quote
Walloper wrote:
This is shite.
Yes, he ought to stick microphones in his ears and show us a 'before and after' graph, but what's quiet for one person on one bike might be deafening for a different person on a different bike, which is why there's no standard test.
Noise is subjective at the best of times. If the OP has found that this works for him, then smashing. Worst comes to worst, someone else tries it and finds that it does bugger all for them and has wasted the cost of two small pieces of foam.
Walloper
PostPosted: 19:40 - 14 Jul 2012    Post subject: Reply with quote
multijoy wrote:
Walloper wrote:
This is shite.
No. There is a standard for noise dB. It is a measurable parameter. As is light, heat, and cetera.
What is not heard/perceived is not less damaging.
EazyDuz
PostPosted: 16:15 - 15 Jul 2012    Post subject: Reply with quote
Walloper wrote:
This is shite.
You are shite.
No, i tested it by putting it on and riding my bike, and it worked, is that a problem?
I guess not.
You guessed correctly, i must be one of the only 21 year old lads without a pair of db monitoring microphones Rolling Eyes retard.
Never said its as good, i said its much improved.
And i say, y u mad tho?
Walloper This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
EazyDuz
PostPosted: 16:26 - 15 Jul 2012    Post subject: Reply with quote
Walloper wrote:
Shut up you disappointing wank mark.
Or what? I mean what are you going to do really lol
21 years old and learned fuck all from the thread?
I learned that you're a typical keyboard warrior cunt Smile
FFS Go deaf ya cunt.
I made the memory foam ear covers to not go deaf, so why would i choose to go deaf?
Then you'll be a deaf dumb retard.
Then i'd be just like you, so no thanks...
EazyDuz This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Walloper
PostPosted: 18:55 - 15 Jul 2012    Post subject: Reply with quote
EazyDuz wrote:
I've yet to see you come up with anything inventive, all you do is troll and act big over the internet, just ignoring you now you've already made yourself look a complete scumbag
Bye bye you little angry man Wink
You penis magnet.
The last post was made 13 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.47 - MySQL Queries: 14 - Page Size: 132.44 Kb
