Checking carb float height.
robbiehall
PostPosted: 12:42 - 09 May 2004    Post subject: Checking carb float height. Reply with quote
Anybody got any tips for doing this the easy way?
Rob
The older I get, the faster I was.
Demonic69
The Pink Rhino
PostPosted: 13:25 - 09 May 2004    Post subject: Reply with quote
If fuel pisses out they're too high, if it doesn't get fuel to the engine they're too low Very Happy
robbiehall
PostPosted: 14:44 - 09 May 2004    Post subject: Reply with quote
Yeah, but does it affect the fuel only when using WOT ?
And how do you actually check the height when the carbs are off the bike ?
Rob
rizzla
PostPosted: 16:21 - 09 May 2004    Post subject: Reply with quote
take the float bowl off and measure the float hight with a ruler
PostPosted: 18:51 - 09 May 2004    Post subject: Reply with quote
No, the float height will affect the fueling on all throttle openings.
You check the float height, normally, with the carbs off the bikeand on there end so that the floats are only just resting on the needle valves (ie, NOT with the carbs upside down). You then measure them, normally from the base of the carb to a point on the floats.
What bike is it?
robbiehall
PostPosted: 20:52 - 09 May 2004    Post subject: Reply with quote
It's my YPVS 350 Yamaha.
So you invert them and then tip the carbs at an angle until the floats swing free from their upside down position....is that right ???
Rob
The last post was made 21 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 48 Kb
