| Author |
| dayokamson |
 dayokamson L Plate Warrior
| Back to top |
| Alpha-9 |
 Alpha-9 Super Spammer
| Back to top |
| dayokamson |
| Back to top |
| Alpha-9 |
| Back to top |
| dayokamson |
| Back to top |
| Boxing |
 Boxing World Chat Champion
| Back to top |
| dayokamson |
 Posted: 14:33 - 25 Jul 2012 Post subject: |
| Sorryunlucky wrote: | When you fit the spark plug, double check the power is off, you'll get a shock if you don't.
And if the spark plug is gone, it'd be black.
Sounds like the spark plug, so change it and then tell us how it went.
And I assume you're not kicking the starter hard enough, be careful though the kick back is a pain in the backside. You could get away with going down with the kick slowly, and as soon as you feel it jam, put your foot down hard and it'll kick up, well should. If not, the kick start shaft is probably gone. |
Thanks man!,
ill remember to check that. got to nip down to halfords to find the proper tools first though. (proper amateur )
Fingers crossed it'll start and i can take it out tonight.
Cheers! |
| Back to top |
| _Iain_ |
 _Iain_ Banned
 Posted: 14:40 - 25 Jul 2012 Post subject: |
Tools are under the side panel above the battery. Theres everything you need to change a sparkplug in there!
Seriously impressed at the mechanical knowledge alpha's picked up scince being on here though!  ____________________ Please be aware that the above post may be full of complete nonsense.
Riding: '07 KTM Duke II, Baotian BT49QT-20 Driving: '88 Volvo 340 |
| Back to top |
| Alpha-9 |
 Posted: 14:58 - 25 Jul 2012 Post subject: |
| Back to top |
| dayokamson |
 Posted: 11:51 - 26 Jul 2012 Post subject: |
Hi Guys,
So i changed the spark plug last night and tried to fire her up but nothing..
im pretty sure i put it in correctly, even though it was a bit of a struggle at first.. Is there any way to check that the new one is on properly and working???
Also it was a bit too dark to check the fuse but ill have a look later today. Are these pretty standard also to buy? or do they vary by bike? (sorry if its a stupid question)
Thanks for all your help!
D |
| Back to top |
| Casper |
 Casper World Chat Champion
| Back to top |
| dayokamson |
| Back to top |
| _Iain_ |
 _Iain_ Banned
 Posted: 13:27 - 26 Jul 2012 Post subject: |
You want a blue spark. If the sparks there, fuel.
I.e crank it over a couple of times with the plug lead disconnected, plug out and it'll hopefully be wet and stink of petrol.
If you're struggling with fitting a spark plug you're doing something very wrong. See the YBR thread in pictures for how to do it. Strip the threads out of the head and you'll be in a whole world of pain. And be looking at a head replacement...£££££££
Other option is to bump it. On the bike, ignition on, first gear, stand on the left peg and ride it like a kiddies scooter, when its rolling sort of jump down on the seat and bang the clutch out. Holding the throttle half opens a good idea too. ____________________ Please be aware that the above post may be full of complete nonsense.
| Back to top |
| Alpha-9 |
| dayokamson wrote: |
Hi Guys,
D |
Finger tighten then give it a quarter turn with your spark plug wrench or w/e you're using, that's all it needs
If you changed your spark plug I doubt that's the issue, if you told them your make and model and they gave you that one it's going to be right unless they fucked up, but I doubt it
Test the spark as others say, but i'd be straight at the fuses, my fuse for my 2009 YBR is 15A, yours may be the same or not I don't know, it'll say on the fuse that's in there
They are pretty standard, you can get them from halfords and any good hardware/parts store (parkers etc)
Check the metal contacts inside it for breaks ____________________ Fzr-600 1999 |
| Back to top |
There is a gap of 2 years, 179 days between these two posts... |
| dannyr |
 dannyr L Plate Warrior
 Posted: 16:09 - 21 Jan 2015 Post subject: ybr 125 wont fire |
Hello Friends... i need some help. I have the yamaha ybr125 2011 fuel injection. its started to play up with not firing up it trys starting and the fuel pump wines like normal but no start every now and then it will start if i bump it even if there is full battery if it was a carb model would be a quick fix but as its fuel injected way over mine and my old mans head... i have drained that battery trying to start with the electric start so im putting it on charge i just need my bike back.... and yes has fuel oil all that needs to be started but not happenin...... hope somone has a good cure. sorry about any miss spelling not my strong point... thanks for your time! ____________________ dan |
| Back to top |
| Alpha-9 |
| Back to top |
The last post was made 11 years, 159 days ago. Instead of replying here, would creating a new thread be more useful? |
