Speedo reading at the drive or clock?
Tbag
PostPosted: 21:45 - 10 Aug 2012    Post subject: Speedo reading at the drive or clock? Reply with quote
Simple question,
Is KPH/MPH determined by the worm gear ratio in the drive by the front wheel, Or.. Behind the clock?
Bike in question is a Hornet 600.
Bezzer
PostPosted: 22:39 - 10 Aug 2012    Post subject: Reply with quote
Usually they use the same worm and speedo apart from an odd different gear inside to sort the odo reading to whatever market it should be. The speedo sweep is the same so it's just a different dial with kph or mph being the main display depending on the market.
Dunno for sure about the Hornet, knowing Honda they might make each one individually for each market. Comparing Euro and UK 'fiches would be the best way to check.
Tbag
PostPosted: 22:41 - 10 Aug 2012    Post subject: Reply with quote
Just checking Fiches now, See whats different in the speedo assys.
The last post was made 13 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.42 - MySQL Queries: 14 - Page Size: 36.13 Kb
