indicator issues.
J4mes
PostPosted: 21:00 - 30 Aug 2012    Post subject: Reply with quote
All the lamp holders clean and corrosion free?
WannaBeDude
Multi meter batt - after that were talking double check connections before we enter the horrible ignition electrical system of utter madness ! Thumbs Up
Scotsman37
PostPosted: 21:26 - 30 Aug 2012    Post subject: Reply with quote
Check for corrosion where the starter solenoid is located because if there is a poor electrical connection your flashers may not fully power up due to that four prong connector that plugs into the solenoid. Spray with WD40 those connectors to the solenoid while switched off!
Check to see if the flashers work bright when the engine is off/on, as that will tell you not enough power is getting through due to a poor connection when off because I had a problem like that with LED indicators not being bright while the engine was off in an earlier bike of mines.
The last post was made 14 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.07 - MySQL Queries: 14 - Page Size: 44.28 Kb
