| Author |
| map |
 map Mr Calendar
 Posted: 01:11 - 30 Aug 2012 Post subject: No drive, any ideas? * Now Sorted Ok * |
At 1am just got back from collecting the lad as the bike, Hyosung Comet Gt125, broke. Looking for come clues as to what to look for and check.
To explain:
Bike had to be left in a pub car park, need to try and collect tomorrow after work.
His story, coming up to junction, braked, knocked it down a couple of gears then went to set off and nothing.
Basically no drive. Can sort of put it in 1st (neutral light goes off) but bike doesn't move. Given the lack of daylight difficult to see if anything actually broken. Clutch lever feels solid but will need to check both ends of cable attached in daylight.
Prior to this he did adjust chain (tighten). Play in chain was OK and he's ridden bike OK since adjustment. I mention this as he did think chain now tighter than when adjusted. So don't know if any bearing on problem. I was thinking to check front sprocket.
So any advice or ideas welcome. Will post any update when I can see it in daylight. Hopefully it's something obvious and I'm hoping cheap and easy to repair (it's the bike's MOT, tax and insurance time in September so that's enough expense to start with).
Thanks in anticipation  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?
| Back to top |
| P.addy |
 P.addy Red Rocket
 Posted: 06:32 - 30 Aug 2012 Post subject: |
The cable holder on the clutch end is prone to coming loose in the older <08 models.
In fact most of the issues are on the <07 models.
| Back to top |
| Ichy |
 Ichy World Chat Champion
 Posted: 06:45 - 30 Aug 2012 Post subject: |
I don't think there is anything to add at all. I find it a little strange that you could knock it into first and it didn't stall or ride off. It suggests a problem with the drive train. Probably just something simple though. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Back to top |
| BigGeeking |
 BigGeeking Scooby Slapper
| Back to top |
| CarlosCBR |
 CarlosCBR World Chat Champion
| Back to top |
| map |
 map Mr Calendar
 Posted: 22:10 - 30 Aug 2012 Post subject: |
Now sorted. Removed cover to front sprocket to find nut and washer not connected to spindle.
Does not explain how chain got so tight!
Anyway, after slackening rear wheel managed to get it all back together and working. Have to keep a watching brief on how things go with chain and sprocket.
Thanks for all the advice  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Back to top |
The last post was made 14 years, 41 days ago. Instead of replying here, would creating a new thread be more useful? |
