Alpha-9 |
Alpha-9 Super Spammer
lozza59 |
lozza59 Nova Slayer
CustomJ |
CustomJ Two Stroke Sniffer
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 23:20 - 07 Sep 2012 Post subject: |
CustomJ |
Teflon-Mike |
Teflon-Mike tl;dr
CustomJ |
Boxing |
Boxing World Chat Champion
Posted: 12:59 - 11 Sep 2012 Post subject: |
Them indicators, feel sorry for you if you drop it by accident. They'll probably be the first things to break in an off. |
map |
map Mr Calendar
CustomJ |
CustomJ |
P. |
P. Red Rocket
foy9999 |
foy9999 Derestricted Danger
Posted: 22:32 - 18 Jan 2013 Post subject: |
Despite the risk of disturbing certain members who don't like ppl talking about the CB125TD I'm going to introduce myself and throw a few things into the mix.
My name is Graham and I have a lot of older, rare bikes that take even longer to deal with but have recently got involved with the CB125 'Superdream'.
My GF's daughter bought one in the summer (1987 model) )and passed her bike test this week and I was tasked with getting it fired up after it sitting for 6 months not used.
She's using it daily but asked if it was possible to get a kick stand for it as she couldn't put it on the main stand.
I did the usual search online for the side stand and, via this thread and various others, learned that's not going to be possible
I taught her how to put it on the main stand on Sunday so she doesn't want a sidestand any more but I'm determined to find one
According to the parts lists viewable online there was one fitted. 50520 - KC1 - 000/920 and to fit it you need bracket 50610- KC1- 000 plus some bolts and springs.
The bracket is like a tube with a plate at each end. The tube goes under the engine and long bolts go throught the brackets and the engine case to secure it.
There appears to be one available here
https://www.cmsnl.com/honda-cb125td-superdream-1988-england_model1408/brkt-side-stand_50610kc1000/ for Euro 31
Once the bracket was on the engine I'm sure you could put a variety of similar sized stands on from another similar sized (Honda?) motorbike.
NB there are 2 centrestands on Ebay just now. I read another Teflon post about repairing damaged originals but that could be a hassle for some ppl |
CustomJ |
CustomJ |
foy9999 |
Posted: 22:54 - 18 Jan 2013 Post subject: |
Cool. Can you put a few pictures up?
Was it just the stand you got from the scrapyard, or was there a similar bracket too?
On all the old Yamahas I have the sidestands bolt to a bracket which mounts on the frame, not the engine.
I'd always assumed all bikes were like the Yamahas. Is the CB125TD unusual in this respect or do a lot of Hondas have this bracket to engine set-up |
CustomJ |
andy_uk |
andy_uk World Chat Champion
CustomJ |
foy9999 |
Posted: 18:09 - 20 Jan 2013 Post subject: |
Hats off to you.
So you've went for the more common approach where the stand is mounted to the frame rather than the engine.
The stand looks like it belongs on the bike.
What type of bike did it come off? |
CustomJ |
foy9999 |
Posted: 04:22 - 18 Mar 2013 Post subject: |
A little addition to the CB125TD(s) stand topic here.
As mention before the gf's daughter has forgotten about a side stand as she can get her CB125TD up on the main stand no problem now.
However, last week, I got a text saying her main stand was falling off.... It was a cold winter night and I couldn't see exactly what was going on but we tie-wrapped the thing to the swing arm so she could get home and I ordered a pin off Ebay as the end has sheared off the one on the bike.
There was a genuine NOS Honda part for £6 on Ebay but it was in South Africa so might've took a while to get here so I went for a used Jialing 125 33 part for £10.25 including P&P.
Anyway I set about fitting it on Saturday and one the stand was taken off it became clear what the problem was. The stand was corroded onto the old pin. The pin itself shouldn't really need to move. I guess the stand is supposed to rotate round the pin but with this one the pin has sheared itself at one end and worn the frame hole oval at the other.
The strange thing was that one I'd hammered the old pin out the stand there was no sign of any grease but there was paint on the pin. Strange
The bike can now be used safely again but next job will be to repair the frame with welding.
One last observation is that the pin was inserted from the RHS but the new one couldn't be put in from that side without removing the exhaust. Not sure if it matters which side it goes in from but it did make me wonder
https://i731.photobucket.com/albums/ww318/foy9999/P1030020_zpsfed5375b.jpg
used Jialing 125 33 centrestand pin versus knackered original
https://i731.photobucket.com/albums/ww318/foy9999/P1030021_zpsb17d0ac8.jpg
not too obvious here but pin hole on LHS of frame worn oval by siezed pin/stand
https://i731.photobucket.com/albums/ww318/foy9999/P1030022_zps39853a48.jpg
https://i731.photobucket.com/albums/ww318/foy9999/P1030024_zpsf286e606.jpg
pin came out with some hammering and still had black paint on it but looks like may never have been greased
https://i731.photobucket.com/albums/ww318/foy9999/P1030023_zps4c68b55e.jpg
these are the holes on the engine casings which the sidestand mount bar would bolt on through. I suspect there are several Honda footrest bars which could fit on here and could be adapted to suit the CB125TD |
c_dug |
c_dug Super Spammer
Posted: 05:41 - 18 Mar 2013 Post subject: |
Skipped most of the thread, in a rush.
If you still haven't found the carb bits give these guys a try https://www.nrp-carbs.co.uk/shop/
Call them if you cant see them on the website. I'd be surprised if they haven't got them. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
foy9999 |
TheSmiler |
TheSmiler World Chat Champion
The last post was made 11 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
