| Flamzypants |
 Flamzypants Nova Slayer
 ..... Quote Me Happy
| bikenut |
 bikenut World Chat Champion
| Flamzypants |
 Posted: 11:22 - 01 Sep 2012 Post subject: |
Bought it private, it had 22000 miles on it, I've only put 50 on since then. Paid £950, is a 07. Was described as operating well, have been happy riding it around. It had an MOT in May under which it only had 1 advisory on the exhaust misbehaving but it was replaced according to the last owner. It was also serviced a few weeks before he passed it over.
Sorry should have made that clear!
I'll have a look for that haynes thing in a tic, I'll just nip outside and get some pictures.
https://imageshack.us/g/255/imag0095c.jpg/ ____________________ CBT - 30/06/11. RIP Sinnis Stealth 18/07/11. Theory passed! CBR125R 16/08/12. Mod 1 Booked. |
| neatbik |
 neatbik World Chat Champion
 Posted: 11:53 - 01 Sep 2012 Post subject: |
If the chain has run out of adjustment then its knackered. A good way to tell is if you can pull it away from the rear sprocket. Any more than a few mm of movement and its worn.
Also look at the teeth on your sprockets (dont forget the front one!) If they are hooked then they are worn out. Here is a photo of a good sprocket next to a worn one -
https://1.bp.blogspot.com/-V6SfncwBQe4/TeewvTjSGII/AAAAAAAABy0/yM7qCfKeaUg/s400/sprockets%2Band%2Bother%2Bthings%2B003.jpg
Also check for tight links in the chain.
Perform those checks and you will be able to tell by yourself if it all needs replacing.
Brake fluid is Hygroscopic, meaning it absorbs water over time. Even though the system is sealed moisture still gets in gradually over time, hence why its reccomended you replace the fluid every 2 years. The garage you took your bike to could well have used a brake fluid tester to gauge the amount of moisture in there.
This is important as water lowers the boiling point.
Changing brake fluid is quite easy when you know how, as is changing the chain and sprockets - but you will need a few tools.
Hope that helps.
Nick
| moppy |
 moppy World Chat Champion
| Flamzypants |
| Aff |
 Aff World Chat Champion
| Flamzypants |
 Posted: 13:36 - 01 Sep 2012 Post subject: |
!! Thanks! ____________________ CBT - 30/06/11. RIP Sinnis Stealth 18/07/11. Theory passed! CBR125R 16/08/12. Mod 1 Booked. |
| BanditMonster... |
 BanditMonster... Derestricted Danger
| bikenut |
The last post was made 14 years, 44 days ago. Instead of replying here, would creating a new thread be more useful? |
