NS125R idal rpm
broomy12
PostPosted: 09:22 - 13 May 2004    Post subject: NS125R idal rpm Reply with quote
What is the idol of a Honda NS125r Mine is popping away at 1500. Is that ok. But some times if i don't keep the reeves up for a few mins it will die out. Might be because its been started from cold. It just seams to sound a bit more healthy at 2000. Cheers for reading and cheers for all feed back. Thumbs Up
rizzla
PostPosted: 09:31 - 13 May 2004    Post subject: Reply with quote
the nsr is meant to idle at 1400 give or take 100rpm let it warm up for 30-60 sec before going any wear you may need to use a bit of choke if you get problems when its warm try and richen the mix
broomy12
PostPosted: 09:38 - 13 May 2004    Post subject: Reply with quote
Only had to use the choke one time. That was when i first got the bike starts up first time everytime.
rizzla
PostPosted: 09:46 - 13 May 2004    Post subject: Reply with quote
you should use the choke when you first start the bike for a while then let the choke in. this should stop it stalling
broomy12
PostPosted: 09:54 - 13 May 2004    Post subject: Reply with quote
Yeah. I also have a another problem. When i'm putting it into gear it jumps loads. Not like just a bit and sometimes that stalls is it something to do with the culch cable is it starched of something? And to top it off when i try and pull away from a uphill i have front break on it will start to pull then cut out it isn't that there isn't enough reeves i don't know what it is. HELP!!!
rizzla
PostPosted: 10:02 - 13 May 2004    Post subject: Reply with quote
how many miles on the clock? i would adjust the slack on the clutch cable if you have a lot of slack you will have to adjust from behind the fairings. the right hand crankcase side of the bike there should be the bottom end of the clutch cable. there is two nuts here that you use to adjust big amounts of slack. If it is not that bad you may need to just adjust from the handle bars. off the top of my head i think you need 2-3mm of freeplay
broomy12
PostPosted: 10:10 - 13 May 2004    Post subject: Reply with quote
Yeah thats about right. But it is adjusted to the max on the handle bars with still 2-3 mm play. will have to to get a new cable if i do how much?
PostPosted: 10:27 - 13 May 2004    Post subject: Reply with quote
Try adjusting the cable, but if that is fine then the chances are the clutch plates are sticking together when it is parked. Try changing the gearbox oil.
As to the choke I would say only use it when needed, and if you can get away with stopping it stalling by using the throttle then do that instead.
craigT19
Jolly Green Giant
PostPosted: 21:23 - 13 May 2004    Post subject: Reply with quote
my 2001 nsr idle speed was between 1k rpm and 1.5k rpm.
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
broomy12
PostPosted: 09:58 - 14 May 2004    Post subject: Reply with quote
Mines an ns125r 1991.
ts50x0
PostPosted: 23:16 - 16 May 2004    Post subject: Reply with quote
when your nsr is cold it is best to use some choke as it is pumpin loads of 2stroke around the engine and this will help it to last longer.
Cool Thumbs Up
The last post was made 21 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 17 - Page Size: 68.22 Kb
