 Speed Could Be A Chat Bot
 Posted: 09:57 - 04 Sep 2012 Post subject: Could it be the coil? |
Hi everyone. After thinking that I solved the issue with my ZX6R Ninja F3 breaking down, I shouldn’t have been so complacent. It konked out the other night and had to push it for a couple of miles back home. Just before it cut out it sounded like it was running on 2 – 3 cylinders then would not start again for love nor money. Tried bumping it but nothing. As soon as I got it back home it started… I replaced the spark plugs and sorted a small hole out in the exhaust and things sound as they should but the bike has flatspots in every gear. Just doesn’t have the acceleration that it used to have. When putting the bike back together after replacing the plugs I noticed that the coil pack was making a weird noise and the bike wouldn’t start so I wiggled a wire to the coil and it started up. Do you think it could be the coil pack that’s causing it to cut out and run lumpy? The 2 spark plugs from that particular coil were in a much worse state than the other 2 (much darker colour) Any advice would be greatly appreciated  |
 sickpup Old Timer
 unitynotsocri... Banned
 Posted: 21:12 - 04 Sep 2012 Post subject: |
depends on the bikes,generally if you dont have the resistance specification you could take a reading off each coil (positive to earth reading and spark plug to the positive and earth) each coils readings value should be the same,a very slight variation is normal,just remember to have the coil wires disconnected from the loom or nthe reading may be spurious.if the coils read the same you can assume they are all ok (or all fked at the same time...very unlikely) then it would be a bit logical to check the cdi unit and maybe the cdi trigger coils(stuffed in with the alternator/flywheel or crank end usually) ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
