| Author |
| GrumpyGuts |
 GrumpyGuts World Chat Champion
 Posted: 21:21 - 08 Sep 2012 Post subject: Changing head gasket on the EN 125 for the first time |
I warned you this would happen
Went out today and bought torque wrench, thread lock compound, gasket dressing, engine oil and an allen wrench. It's finally time to change the head gasket.
I will start off by stating that this is the first time I've ever attempted this...on a four stroke
Armed with plenty of bacci, Relentless, the Oracle what is called Haynes and my left arm in a cast, it begins!
1) Like I said, plenty of stimulants
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08153631.jpg
2) Drained the oil from the bike. New engine oil purchased. Note the milk carton with the old oil which now also contains a screw bit after dropping the bugger
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08153226.jpg
3) Removed the seat and fuel tank bolt (only one bolt as the other has bloody sheared off)
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08153234.jpg
4) Removed fuel tank and stored elsewhere (heavy!)
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08153334.jpg
5) Removed battery for safety
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08153615.jpg
6) Removed sprocket cover (access to the alternator cover)
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08165758.jpg
7) Removed spark plug cap and plug itself
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08165127.jpg
8) Removed carb from the inlet manifold and placed slightly to the left, tacho cable, both cylinder head covers, tacho drive assembly screw and cylinder head steady
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08162423.jpg
9) Removed exhaust and frame earth
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08164333.jpg
10) FINALLY removed tacho drive after much swearing. I have damaged it (oops) but it was in there! Stored safely as to not dry up.
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08173138.jpg
11) Removed the inlet and exhaust valve inspection covers
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08175742.jpg
12) I then went about setting the engine to TDC (Top dead centre). I did this by removing the inspection nut on the crank case, removing the alternator cover and rotating the alternator rotor until the markers matched up (not pictured)
13) Removed the 10 cylinder head bolts in order according to Haynes to evenly distribute the force of removing them (taken before valve covers were removed) and making sure I do not disturb the two rocker bolts.
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08174956.jpg
This is the sheet of paper I've used to number each bolt. Very handy technique...
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08181548.jpg
14) Removed rocker cover. This was a c*nt to remove and required several soft taps with a mallet.
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08181454.jpg
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08181504.jpg
15) Observing the mess
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08181600.jpg
16) Removed cam chain tensioner bolt and tensioner
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08183047.jpg
17) Removed cam sprocket bolts
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08190400.jpg
18) Removed cam shaft, cam sprocket, that circlip thingy and inserted a rod to prevent the chain falling down the tunnel
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08190810.jpg
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-08190816.jpg
I then started undoing the head bolts, but I've hit a brick wall. ONE screw won't budge. There are 4 nuts on top of the cover and two on the left side of the engine retaining the cylinder head cover. One of the side screws won't move. The nut should stop halfway so it would begin to unscrew the rod but it was come all the way off, leaving the rod hanging there like a bellend.
Will update tomorrow as it has now gone dark. I've coated the thread in compound and will try to remove it tomorrow.
 ____________________ My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012 |
| Back to top |
| GrumpyGuts |
 Posted: 13:51 - 09 Sep 2012 Post subject: |
Ummm....
https://i47.tinypic.com/iyprw4.jpg ____________________ My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
| Back to top |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 14:02 - 09 Sep 2012 Post subject: |
| Back to top |
| karthead |
 karthead Trackday Trickster
 Posted: 14:06 - 09 Sep 2012 Post subject: |
The first time i've ever done something to a 4-stroke was a head gasket change except on a car... Good luck! |
| Back to top |
| GrumpyGuts |
| Back to top |
| GrumpyGuts |
 Posted: 18:18 - 10 Sep 2012 Post subject: |
Update:
https://i47.tinypic.com/34fbbz9.jpg
That's Peter the Piston. Peter looks a bit worn and choked of carbon. Replacing Peter, along with his rings with a kit ordered from Wemoto.
Cylinder didn't look too bad. No deep scratches, marks or scorch marks. Just cleaned and lightly oiled it, which includes the rest of the barrel which was coated in oil.
https://i50.tinypic.com/332oy8p.jpg
That is the old head gasket...it was literally a thin piece of metal with no gasket material so no wonder oil was splashing out!
New base gasket ordered, too. Knowing Wemoto my stuff should be here tomorrow, so I'll post the pictures tomorrrow  ____________________ My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
| Back to top |
| lukamon |
 lukamon World Chat Champion
| Back to top |
| orac |
 orac World Chat Champion
| Back to top |
| GrumpyGuts |
| Back to top |
| Frost |
 Frost World Chat Champion
 Posted: 20:47 - 10 Sep 2012 Post subject: |
New piston and rings can never hurt. Put some loctite on the cam chain sprocket bolts as if they come loose you're fucked
Cleaning the shit out of all mating surface helps when it come to torquing bolts up. A smear of hylomar doesn't hurt either but i guess it depends on how fussy & rich you're feeling.
Remember shit loves sticking to oily bits and a few well placed bits of grit can cause a lot of wear so it's probably with cleaning then re-oiling the moving bits as they go back together.
The two most important things are timing and valve clearances (how are the valves?) when it comes to putting it all together again as it might run like shit, or not run for very long depending on how badly you cock it up  |
| Back to top |
| Frost |
| Back to top |
| GrumpyGuts |
| Back to top |
| _Iain_ |
 _Iain_ Banned
 Posted: 00:26 - 11 Sep 2012 Post subject: |
Winning. I like threads like this.
 ____________________ Please be aware that the above post may be full of complete nonsense.
Riding: '07 KTM Duke II, Baotian BT49QT-20 Driving: '88 Volvo 340 |
| Back to top |
| Frost |
| Back to top |
| Islander |
 Islander World Chat Champion
 Posted: 00:57 - 11 Sep 2012 Post subject: |
Don't forget to gap the rings before you fit them and make sure that the gaps on the three rings are spaces at 120 degrees to each other.  |
| Back to top |
| GrumpyGuts |
| Back to top |
| Frost |
| Back to top |
| GrumpyGuts |
| Back to top |
| Frost |
| Back to top |
| GrumpyGuts |
| Back to top |
| Frost |
| Back to top |
| GrumpyGuts |
| Back to top |
| GrumpyGuts |
| Back to top |
| dungbug |
 dungbug Could Be A Chat Bot
 Posted: 23:19 - 18 Sep 2012 Post subject: |
| Back to top |
| GrumpyGuts |
 Posted: 17:25 - 21 Sep 2012 Post subject: |
Well got some pictures off my phone, it's all done. Really the only thing I need to do is check valve clearances.
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-11141503_zps21be948b.jpg
The piston on the left is the old one with the obviously new one on the right. A lot of difference there!
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-11142628_zps762c22b0.jpg
The new piston installed with...
https://i77.photobucket.com/albums/j69/willyrobbie/2012-09-11144754_zpsfe7b0b5c.jpg
The new head gasket!
If anyone is thinking of doing this, don't make the mistake I did by taking out the tensioner blade before the cam chain tensioner assembly. Moving the chain after caused it to dislodge off the bottom sprocket and you will end up needing a flywheel pulley to remove that!
Here is a Youtube clip of the bike with the engine running. I'm selling the bike now, cost me too much money and to be honest there's a mint condition CG 125 waiting for me, so I'm prepared to cut my losses  ____________________ My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
| Back to top |
The last post was made 13 years, 318 days ago. Instead of replying here, would creating a new thread be more useful? |
