| Author |
| AJ9000 |
 AJ9000 Nova Slayer
 Posted: 14:24 - 13 Sep 2012 Post subject: Non motorised bicycles |
In a moment of weakness I have agreed to do a triathlon next June. It is the half Ironman distance, meaning a bike ride of 56 miles. I don't have a bike. (I also don't (not can't) swim, because I find it interminably boring, but that is another topic).
So, I need a bicycle, assuming I can't do it on my Kawasaki. Now I know absolutely nothing about them, other than the number of wheels, but an amount of research indicates that "entry level" proper bikes are about £700 upwards. Given the length of the ride, and, therefore, the loads of training miles I will have to do, I feel I do need a decent light bike so I won't be doing the run like John Wayne with piles.
My question though, is where (i.e. at what price point) will I stop feeling the difference?
I also don't understand the shoe/clip thing so any help appreciated,
TL:DR I need a decent bike, how much should I spend?? |
| Back to top |
| ToxicChicken |
 ToxicChicken Derestricted Danger
 Posted: 14:26 - 13 Sep 2012 Post subject: |
Not sure about the whole bicycle thing. But I used to do spinning classes and lots of people wear them there as apparently they help you to kind of push and pull with your feet and obviously grip the pedals. Makes it easier I suppose! hope that's a but helpful. Hope it goes well! |
| Back to top |
| kotachi |
 kotachi Traffic Copper
 Posted: 14:32 - 13 Sep 2012 Post subject: |
You can get a perfectly good road cross (bike with a frame that CAN be fitted with off-road wheels and tyres but is usually a road bike) for around, as you say, £700.
You can spend in the region of £1-£3k for a competitive triathlon levelled bike, one of my friends is a Loughborough Triathlete and her bike is worth £4k, but assuming you are merely doing it for the challenge/charity/some other equally noble but not competitive reason, then a road cross should be fine.
And with regards to clip-on's, there are basically 3 types of pedal, normal pedals, cages and clip-on's.
With respect to triathlons and long rides;
normal < cages < clip-on's,
as each level makes the up-pulls easeir and more efficient! ____________________ CBT done - 24/03/2012, theory test done - 03/04/2012.. Mod 1 done -26/06/2012, Mod 2 done - 29/06/2012. Current steed: Cage.
Suntan Sid said: "Look at it this way, your employer wants to pay you the minimum amount, it thinks it can get away with, and extract from you the maximum amount of graft. Ergo it's your responsibility to ensure that karma is restored and you do as little work as you think you can get away with, for the maximum amount of money." |
| Back to top |
| stinkwheel |
 Posted: 14:54 - 13 Sep 2012 Post subject: |
Go second hand.
You can get decent quality, older racer bikes fairly cheaply. Especially if you get one from the pre brifter era (brifters are brakes and gear shifters in one so you pull them to brake and knock them sideways to change gear).
If you're prepared to have a gear shift on the crossbar, you can get competition standard racer bikes for a couple of hundred quid.
Most cities will have a bicycle recycling co-op/charity and all the wee scrotes want mountain bikes, not racer bikes.
Look out for anything with a Reynolds steel tubing frame.
You want 700C size wheels, alloy rims and you want some super-skinny tyres with loads of pressure in them. Don't worry too much about fancy brakes, you can upgrade to modern callipers.
Some of the really good ones will have campagnola gears but be aware that they use odd sizes so if they need parts, it can be expensive. Shimano 105 is generally accepted as the entry-level gear stuff for serious competition.
Don't get one off ebay unless you're going out to see it. The geometry is WAY more important than the sum of the parts, it's got to fit you.
Sheldon Brown was always the oracle on all matters bicycle. He was a prolific web author and all his stuff has been kept for posterity. Have a good browse about. If there is anything you need to find out about a bicycle, add "sheldon" to the search string and there will usually be a detailed article:
https://sheldonbrown.com/beginners/index.html
You see stuff like THIS
It's old fashioned but people were using bikes like this in the tour de France 20 years ago. It has a superb quality steel frame and campagnola everything. This bike would have cost several thousand pounds when it was new. BUT you really do need to sit on them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| AJ9000 |
 AJ9000 Nova Slayer
| Back to top |
| stinkwheel |
 Posted: 08:59 - 14 Sep 2012 Post subject: |
| AJ9000 wrote: | Thanks everyone, and especially stinkwheel.
In terms of geometry, having not ridden a racing bike, how will I know if it fits. Evidently if it is far too small or big I should realise but it seems that frames come in 2cm increments. Would that matter as the saddle can adjust? |
Have a browse about on Sheldon Browns sites. Here's a good starting point:
https://sheldonbrown.com/frame-sizing.html
Long and short of it, the actual stated frame size is irrelevant because it's meaningless other than to compare two bicycles of the same make and model. You have to sit on it and see how far forwards you are having to reach, the height of your hands in relation to your backside and how far back or forward your feet land up being. The length of the top tube and headset (the bit the bars attach to) dimensions are much more important than the frame size.
OR, if you go into a proper independant bike shop, you can pay someone who knows what they are doing to do you a fitting session. Importantly, you are paying them for the fitting session, NOT to sell you a bike, otherwise it will miraculously turn out that this one the have in stock just happens to be the perfect size for you. Much cheapness, suits you sir.
By proper bike shop, I mean an independant bicycle shop that has a small selection of four-figure bicycles on display in the window, not a multi-national chain and ESPECIALLY not halfords who might, on rare occasions, accidentally employ someone who is passionate and knowledgeable about bicycles. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| D O G |
 D O G World Chat Champion
 Posted: 10:57 - 14 Sep 2012 Post subject: |
While Stinkwheel is helpful, I do disagree with him on the vintage bike thng.
Parts will be more difficult to comeby, the wheels will probably be past their best (stuck nipples anyone), it will be heavier, will need more care and will probably be more worn than something newer.
I'd go second hand, but a mosdern Alu frame and Carbon fork, with Shimano kit (105 is fine as Stinky says).
Something like this....
2 Year old Specialized for £550. |
| Back to top |
| hellbound |
 hellbound World Chat Champion
| Back to top |
| stinkwheel |
 Posted: 12:58 - 14 Sep 2012 Post subject: |
| D O G wrote: | While Stinkwheel is helpful, I do disagree with him on the vintage bike thng.
That does indeed look like a bargain.
Suspiciously cheap though for what it is?
On a more technical than we need to be getting into point, I wouldn't say lightness is necessarily everything and a high-end steel frame would be weighing in at about the same as a mid-rage alu one. Stiffness and ride quality have an important part to play and steel frames are, in general, much nicer to ride on.
I rode a very expensive carbon frame bike once and it was awful. It bent and flexed in disturbing ways and the front wheel kept coming up off the ground if you tried to power up a hill. They are light but take some technique to ride and you're constantly up and down the gears.
Mrs stinkwheel agreed and went down the titanium route.
But broadly, yeah. Aluminium is a good compromise between the ride quality of steel and the lightness of carbon.
I suppose the weight of the OP would also be a potential factor. If he's like me (I'm a big guy) then it's worth taking into consideration that a lot of the super lightweight bike componants simply will not stand the strain. I've bent dropouts, stripped out cranks and even snapped hubs before, just by stomping on the pedals. Racing cyclists are light.
EDIT: And don't get me started to what 17 stone banging on the pedals does to a 10 speed chain and cassette. Sometimes less is more. A 7 speed chain can just about cope with me battering at it. After 25 miles on the hills in Majorca last year I had the 10 speed chain physically rattling because the plates were so loose and stretched.
Dork? Moi?
https://i48.photobucket.com/albums/f216/stinkwheel/mallorca%202010/DSCN0565.png ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| D O G |
| Back to top |
| Drew |
 Drew Banned
 Posted: 21:40 - 14 Sep 2012 Post subject: |
On cycle forums, the Triban 3 gets great reviews as a budget / beginner road bike. |
| Back to top |
| AJ9000 |
 AJ9000 Nova Slayer
| Back to top |
| stinkwheel |
| Back to top |
| AJ9000 |
 AJ9000 Nova Slayer
| Back to top |
| stinkwheel |
| Back to top |
| Carl_steveo |
 Carl_steveo World Chat Champion
| Back to top |
| AJ9000 |
 AJ9000 Nova Slayer
| Back to top |
| JonB |
 JonB Afraid of Mileage
| Back to top |
| truslack |
 truslack World Chat Champion
| Back to top |
| AJ9000 |
 AJ9000 Nova Slayer
| Back to top |
| G |
 G The Voice of Reason
| Back to top |
The last post was made 13 years, 166 days ago. Instead of replying here, would creating a new thread be more useful? |
