Can you just take out the old cct and put the new one in?
WULFSTAN
PostPosted: 12:35 - 24 Sep 2012    Post subject: Can you just take out the old cct and put the new one in? Reply with quote
Like the title says really bike is a cbr 600 f l 1990 thanks
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
spikenipple
PostPosted: 12:58 - 24 Sep 2012    Post subject: Reply with quote
No, because if the cam chain skips a tooth in the process you'll end up with one very fucked engine.
Set the engine to TDC on cylinder 1, gently remove the current CCT, fit the new one making sure everything's clean and no shite has got into the hole, tension it up and then turn the engine over several turns by hand (socket on the end of the crank). If that's ok then fire her up once you're sure everything's back together properly.
C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike
MaybeGuy
PostPosted: 13:32 - 24 Sep 2012    Post subject: Reply with quote
Ignore the above. On a 4cyl bike it's fine to take it out and replace it.
spikenipple
PostPosted: 14:10 - 24 Sep 2012    Post subject: Reply with quote
Really?
stonesie
PostPosted: 14:33 - 24 Sep 2012    Post subject: Reply with quote
I would still do it at TDC1 just to be sure that all the slack was on the tensioner side of the chain.
MaybeGuy
PostPosted: 15:03 - 24 Sep 2012    Post subject: Reply with quote
So what are the other cylinders doing whilst it's at TDC1? It makes no odds.
spikenipple
PostPosted: 17:31 - 24 Sep 2012    Post subject: Reply with quote
The reason I suggested putting it to TDC is that in the (admittedly unlikely) event of the chain slipping, you know where the engine is and where the cams should be.
The Artist
PostPosted: 17:33 - 24 Sep 2012    Post subject: Reply with quote
I am not familiar with cbr tensioners but surely you could just loosen off the spring inside, then remove it, that will keep it tensioned until it is right out and just pop the new one in.
WULFSTAN
PostPosted: 17:43 - 24 Sep 2012    Post subject: Reply with quote
thanks Thumbs Up
Frost
PostPosted: 17:49 - 24 Sep 2012    Post subject: Reply with quote
So long as you fit the new one in the correct order it'll be fine.
Reset it, put the first part in and bolt it on properly, then put the spring in.
The last post was made 14 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.37 - MySQL Queries: 14 - Page Size: 65.36 Kb
