| Author |
| Rogerborg |
 Rogerborg nimbA
 Posted: 21:29 - 27 Sep 2012 Post subject: Wrist deep in my own muffs |
OK, muffs are the way to go, we all agree. Tucano Urbano seem to be the favoured brand. But what if you were a cheapskate Scotch apologies for the redundancy and wanted to DIY yourself a pair?
You would need:
1 x Amazon packing box (other pieces of cardboard may be suitable, I'm guaranteeing nothing).
1 x manky old wool flokati rug, which has already been cut up to make a Hiccup Horrendous Haddock III furry vest for Master Borg.
1 x piece of cheap vinyl fabric left over from a seat project.
Waxed linen thread, some.
Cable ties of securingness x 2.
First, cut your cardboard to the approximate desired shape of your muffs. You'll want from the outside of the grips to covering your brake reservoir and assorted LHS switchgear. Length should be from well clear of the levers to past your wrist.
Then, secure your flokati from the cat. The Glaring Paw of Ownership is confirmation that it's suitably cosy.
https://i45.tinypic.com/2m81p8i.jpg
Give it a thorough brushing, you don't want any tugs in there to catch on your controls or fingers.
Next, cut out 2 pieces of flokati, sized generously larger than your cardboard template.
https://i46.tinypic.com/2h5jzw3.jpg
Turn the fuzzy side inwards, fold in half and stitch down the whole length of one side. This will be the outside edge.
https://i46.tinypic.com/33natci.jpg
Stitch together a few inches at the end of the other side, leaving a big enough gap to slide it over your controls.
https://i47.tinypic.com/2igc7kh.jpg
Now cut out enough vinyl to wrap around your fuzzy muffs, again leaving plenty of overlap.
https://i49.tinypic.com/ogkhvr.jpg
Fold in half, inside out, and stitch down one side. For extra chintz, do a little corner on it.
https://i50.tinypic.com/2120i.jpg
Turn right-way-out and stuff your muff inside it. Put a few stitches through both materials to hold them together. Then on the inside length, fold the loose edges of the vinyl over the inner and stitchy-stitch, again ensuring that there's a hole there that can slip over the bars and controls.
Here you can see I've trimmed some excess vinyl off of the bottom of the cuff edge, leaving a little overlap at the top for (probably imaginary) weather protection.
https://i45.tinypic.com/mhzmhe.jpg
And that's it. You're done.
https://i45.tinypic.com/2nltm68.jpg
Be honest, would you rather wiggle your fingers into some cheap polyester bag, or plunge into this lush, inviting, hairy muff?
https://i46.tinypic.com/23vjfpe.jpg
Attached to a motor bicycle. I have bar ends (and mirrors) so just poked holes in the muffs with my leatherworking awl (we've all got one, right?), put some big washers on the inside and outside and bolted them on. Make sure they're well clear of the levers at the front, and that the throttle is free to rotate.
Add cable ties, shoelaces, duct tape or whatever it takes to keep everything ship-shape and Bristol fashion at the inside edges.
https://i45.tinypic.com/3495lc7.jpg
Then post a photostory before trying them out. What could possibly go wrong, after all?  ____________________ Biking is 1/20th as dangerous as horse riding.
| Back to top |
| BravoCharlie |
 BravoCharlie World Chat Champion
| Back to top |
| N cee thirty |
 N cee thirty Banned
| Back to top |
| Rogerborg |
 Rogerborg nimbA
| Back to top |
| Frog |
 Frog Traffic Copper
 Posted: 23:39 - 27 Sep 2012 Post subject: |
Mr Borg, you truly scare me
The first piece of muff-making comedy I've ever read. Top work
Let us know:
A) how well they work in wet weather
B) when the cat finally removes it's claws from your arm/legs/man bits ____________________ CBT 23/09/10 - Theory 19/03/11 - Mod1 19/04/11 - Mod2 06/05/11
Bikes: CBF125 (sold 30/10/10-25/09/12) - CB400 24/06/11 (broken) - ER6-f 25/09/2012  |
| Back to top |
| goto10 |
 goto10 World Chat Champion
| Back to top |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| Back to top |
| MarkJ |
 MarkJ World Chat Champion
| Back to top |
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:25 - 29 Sep 2012 Post subject: |
Now tried out, needed a bit more cable tying along the inside edges to minimise the gaps, but success succeeded.  ____________________ Biking is 1/20th as dangerous as horse riding.
| Back to top |
| Teflon-Mike |
 Teflon-Mike tl;dr
| Back to top |
| Ayrton |
 Ayrton World Chat Champion
 Posted: 15:12 - 29 Sep 2012 Post subject: |
Good guide
Im going to make something like this, but put them around some hanguards to stop them catching the levers. |
| Back to top |
| map |
 map Mr Calendar
| Back to top |
| Spudly |
 Spudly World Chat Champion
 Posted: 19:54 - 29 Sep 2012 Post subject: |
I heard copper wire was invented by two scotsmen fighting over a penny.
Ingenius work there Mr. Borg. Considering I once riveted together a kangaroo skin bikini for my wife, I feel confident in having a go at this. ____________________ The Old Apprentice |
| Back to top |
| P.addy |
 P.addy Red Rocket
 Posted: 23:22 - 29 Sep 2012 Post subject: |
I found riding at anything above 40ish, ones not secured properly pushed on the brakes/clutch.
Well done on bothering to make them..
Woman...  |
| Back to top |
| TUG |
 TUG World Chat Champion
| Back to top |
| Rogerborg |
 Rogerborg nimbA
 Posted: 02:27 - 01 Oct 2012 Post subject: |
| awrowe wrote: | Considering I once riveted together a kangaroo skin bikini for my wife, I feel confident in having a go at this. |
It was touch and go whether I stitched it, or busted out the double cap rivets and the Hammer and Anvil Shaped Object of Shortcutting.
| ##Paddy## wrote: | I found riding at anything above 40ish, ones not secured properly pushed on the brakes/clutch. |
I was concerned about that too, but it's a beefy enough muff to stand up to some "private road" abuse. It likely helps that they're bolted tight to the bar ends. If not, shoving a rigid member into the muff should provide satisfaction. ____________________ Biking is 1/20th as dangerous as horse riding.
| Back to top |
| i.p.phrealy |
 i.p.phrealy World Chat Champion
 Posted: 23:35 - 30 Nov 2012 Post subject: |
Right, Dunelm Mill is 400 yards up the road from here, feel a craftworky day is on for tomorrow!  ____________________ it is impossible to lick your own elbow...
Finally allowed a big bike 19/03/14! |
| Back to top |
| iMark |
 iMark World Chat Champion
| Back to top |
| stevo as b4 |
| Back to top |
| Slacker24seve... |
 Slacker24seve... World Chat Champion
| Back to top |
The last post was made 13 years, 323 days ago. Instead of replying here, would creating a new thread be more useful? |
