| ultinator |
 ultinator Derestricted Danger
 Posted: 17:38 - 01 Oct 2012 Post subject: CB250, attempted hot-wire |
Had some numpty attempt to steal a bike from my residence. found it in a river, pulled it out and got it home, fine no big deal.
The problem is that they have pulled all the cables from the bottom of the ignition switch?(where u put the key in) and now the only way to start it is by connecting black to red and starting it. the key is obsolete because of this.
Rectification issues lie within the fact that I can solder them back on but there are 6 cables green, red, black, brown, brown with a stripe, and black with a stripe.
Is anyone able to tell me which goes where or even better does anyone else have a cb250 (its quite old maybe early 70's) and could supply me with a photo that i can work to, would rather fix this myself that pay to take it somewhere.
Also i know i could get a replacement but considering all that needs doing is to put the wired where they came from......you know.
Cheers any help much appreciated,
Mike |
| Matt- |
 Matt- World Chat Champion
| ruck bodgers2 |
 ruck bodgers2 Scooby Slapper
 Posted: 19:02 - 01 Oct 2012 Post subject: |
absolutely no point getting a new unit i wouldnt bother . what would be the bennifits . none considering your is okay just needs solderin
im with you on fixing the one u have . i hate wiring bud . i once made a complete loom and it was honestly less hassle than connecting up a factory one minus the block connectors .unless when they have yanked the wires out they have broke the circuit or contact points off . but it sounds like you have already had a mooch inside
ave a look here . blue box of bottom of diagram . should be able to work it out from that with a little head scratching. . good luck . sorry to hear about the theft. neeed any more help upload a couple of pics of the disc on the bottom of the assembly the wires go to and we will work it out
https://www.elektronik-sachse.de/AAC/diagrams/honda_cb350.jpg
edit* ive posted u up the wrong diagram havent i . ill find u another tommorow ____________________ throw it up the wall |
| bikenut |
 bikenut World Chat Champion
| ultinator |
| ultinator |
| ruck bodgers2 |
 Posted: 22:53 - 02 Oct 2012 Post subject: |
great pics big help
wen u turn the key all it does is rotate a parallel to that one thats on the inside the 3 posistions of the key at each stage will allign the contact points on each disc creating your circuit . you already know witch two wires are your igntions . so for now if you need to use the bike all you need to do is unbolt the ignition unit from the top yoke so its a bit easier to access and try
the two ignition wires on the contact.
with your key in the on possistion until you find the rite combination .
dont worry i doubt you will blow any fuses. if you have
a multimeter even better u can just test the circuit.
look what i just found https://www.davidsilverspares.co.uk/graphics/parts/35100413007P_1_large.jpg
hold the ctrl button on your keyboard and push + key a few time to zoom in to get a closer look wa hayyyyyyy
the other wires was just to your instrument lights and wot not ____________________ throw it up the wall |
| bikenut |
| bikenut |
 Posted: 10:05 - 03 Oct 2012 Post subject: |
that didnt work so will sort out for 2morrow, in shed this afo and quess what??????have some switches there as well as wire diagram etc.......
back 2morrow.
pic would be easiest and will try at daves later to upload pic and diagram.
google superdream and see what comes up!! wink wink  |
| bikenut |
| bikenut |
| bikenut |
| ruck bodgers2 |
| ultinator |
 Posted: 19:37 - 03 Oct 2012 Post subject: |
Holy cow, wow thanks that was extremely helpful!
All done, soldered and functioning correctly....I think.
The two rear indicators are broken, one completely and the other works and flashes but it isnt mounted no more.
Thing with these are when indicating RIGHT the indicator lamp on the dash doesnt flash but both front and back bulbs to.....
When indicating LEFT (rear left not working) the indicator lamp on the dash stays permanantly on..
Im assuming this is to do with the fault and lack of indicator coompleteing a circuit we have replacements on the way so will see then just wanted to know if anything terrible will pop up??
ALso Thanks again for all your help...you guys have been more than helpful and for that im grateful |
| ruck bodgers2 |
| bikenut |
| el_oso |
 el_oso World Chat Champion
| bikenut |
| ruck bodgers2 |
| bikenut |
| honda cg 1992 |
 honda cg 1992 L Plate Warrior
| bikenut |
The last post was made 13 years, 149 days ago. Instead of replying here, would creating a new thread be more useful? |
