| Hangear |
 Hangear Two Stroke Sniffer
 Posted: 00:18 - 14 Nov 2012 Post subject: Replacing sprockets, worth upgrade? |
Hi guys.
Did a bit of TLC on my Derbi Senda XTreme R 50 workhorse that gets me from A to B every day. It's done about 3800 miles since I bought it new last july.
Today I noticed the sprockets teeth have been worn and therefore the sprockets need replacing (mainly due to my poor maintenance in the chain).
Basically, since i will be ripping the old sprockets off and changing them, should I try a different ratio? I feel my gears are very similar (I have 6 to do 32 mph) and I would like to vary them out a bit more. I would love to be able to do a higher speed uphill as that's about 18 mph.
What sprockets would you recommend guys?  ____________________ Sup |
| Kickstart |
 Kickstart The Oracle
 Posted: 01:19 - 14 Nov 2012 Post subject: |
If you are slowing down that much up hill then either it is a very steep hill or the gearing is too high (in which case changing to a lower gear might help).
An attempt to explain it follows!
You need X thrust to go at a particular speed. X being made up of the amount needed to overcome rolling resistance (ie, down to weight which is small and pretty much fixed whatever speed you are doing) and wind resistance (which increases rapidly with speed).
The engine produces thrust which is down to how much torque you have (NOT power), and then that is changed by the gearing. It is engine torque times the gear ratio (which is smaller in the higher gears). Hence as you use a higher gear (or use sprockets to give higher gearing) you get less thrust pushing the bike forward; but if you use a lower gear at the same speed you might well land up using revs well beyond those where torque is falling away rapidly.
So gearing is a balancing act.
| Walloper |
 Walloper Super Spammer
 Posted: 08:25 - 14 Nov 2012 Post subject: |
Lay off the Pies fatty...
Get more supple so you can reduce your profile.
Become more Aerodynamic.
Tuck your knees and elbows in and get your big head down.
Probably find the gearing is set for optimal/general use. Or for what you are doing with it.
It would probably only be advantageous to modify the gearing for use on a track or special special circumstances.
Your main issue is the power (The overall combination of Torque/Brake Horse power Stuff) the engine can produce.
As Kickers says, it is like swings and roundabouts. Lower gearing more appreciable oomf when accelerating and going up hills but rubbish cruise and top speed.
Higher gears will give rubbish acceleration and hill climbing ability but superb cruise and top end. (So long as the head wind is not too severe as wind can act like a hill or heavy weight).
Get down the gym and eat more fruit
and veg.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| garth |
 garth World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:01 - 14 Nov 2012 Post subject: |
It's going to come down to where the peak torque and power are on your bike, and getting the gearing sorted so that you hit them at (or just before) your desired top speed.
Lengthening the gear ratios might give you a bit more top end, but the most likely result is that you'll just never get to the, uh, "powerband" in the top gears, and so won't use them anywhere except on downhill runs. It'll do nothing for hill climbing, that's just a lack of torque and power.
You may even need to shorten the gearing if you want to use 6th effectively. Again: it'll be entirely dependent on your engine's performance characteristics and the current gearing, you'll need to have a think about that yourself.
What I will say is that lengthening the gearing might make the bike feel bit less frantic. Going from 15 to 17 teeth on the front sprocket of my 125 made it feel much more relaxed, but for actual performance increases you'll need more torque and power, not more gearing. ____________________ Biking is 1/20th as dangerous as horse riding.
| barrkel |
 barrkel World Chat Champion
 Posted: 12:50 - 14 Nov 2012 Post subject: |
| Kickstart wrote: | The engine produces thrust which is down to how much torque you have (NOT power), and then that is changed by the gearing. |
Power is relevant rather than torque because of the gearing.
Max torque at the wheel is achieved at max power RPM from the engine with gearing to match the road speed.
Peak torque RPM from the engine is mostly irrelevant information; when RPMs are at peak torque for any single gear, you can usually get better acceleration / more wheel torque by downshifting. Getting the RPMs to peak power by adjusting gearing gets you what you want (max acceleration or max speed).
An engine could have the torque of a hamster wheel, but at a high enough RPM, it would have monstrous torque when geared down.
Torque curve OTOH is very relevant for what a bike is like to ride. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| Kickstart |
| Walloper |
| Kickstart |
| barrkel |
 Posted: 18:00 - 14 Nov 2012 Post subject: |
| Walloper wrote: | Anyone fancy nipping out for the popcorn before we get started here? |
I think Keith and I are roughly in agreement, just talking about slightly different aspects of the implications in practice.
I remember once upon a time reading a monstrous thread on some other forum - must have been over 10 pages - mostly between two guys debating whether peak torque vs peak power was more relevant, or some such. What the guy on the torque side missed was that torque on its own is meaningless, you have to take the RPM into account; and if you use gearing to halve the RPM, you double the torque. So if you have the ability to change gears[1], power is the only interesting number, since power is torque x RPM (x some constant to suit your desired unit of power).
[1] In an ideal world, the gearing would be infinitely adjustable and keep RPM constant for max acceleration, and the fastest bikes would all sound a bit like scooters  ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| Walloper |
| Kickstart |
| Walloper |
 Posted: 18:24 - 14 Nov 2012 Post subject: |
| barrkel wrote: | | Walloper wrote: | Anyone fancy nipping out for the popcorn before we get started here? |
[1] In an ideal world, the gearing would be infinitely adjustable and keep RPM constant for max acceleration, and the fastest bikes would all sound a bit like scooters  |
Yes agree and understand this.
But we were presented with:
"Basically, since i will be ripping the old sprockets off and changing them, should I try a different ratio? I feel my gears are very similar (I have 6 to do 32 mph) and I would like to vary them out a bit more. I would love to be able to do a higher speed uphill as that's about 18 mph.
What sprockets would you recommend guys?"
I would NOT phaph about with the bike in question as the power/torque range is limited/narrow.
For a small engined commuter it's just a case of dealling with it. Coz if you make it good on hills you'll probaly hate it on the flat. And visa versa.
For a track we can fanny about with gearing to match 'Ooomph (the noise for 'Push' not Zero Zero Zero Miles Per Hour) from the engine to expected gradients/bends. For the high street I don't think I'd waste the beertime.
The issue with the bike in question is that the range of the power/torque delivery is too narrow.
To save a thirty page thread....
If hills are predominant on the commute then smaller front or larger rear.
But only one tooth either front or rear not both.
Try it and see. If you like it then good if not then swap back to OEM specs.
BTW I hate Popcorn. I'd much prefer a Hotdog. No ketchup but tons of mustard. Please. Ta. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| YBR Ric |
 YBR Ric Spanner Monkey
 Posted: 18:47 - 14 Nov 2012 Post subject: |
I wouldn't want to influence your descision in any way, but all being equal, a smaller sprocket wears out quicker than a larger one  |
| barrkel |
 Posted: 18:51 - 14 Nov 2012 Post subject: |
| Walloper wrote: | But we were presented with:
What sprockets would you recommend guys?" |
Yes, to answer the OP, to absolutely maximize your speed on that hill, you'd need to figure out (either with mathematics or playing around) how much power exactly is needed to overcome friction + drag, then have a gear that maps peak engine power to that speed, + some close gears below that to bring the speed up so that gear could be used.
But such a setup would be optimized for that exact hill and for the assumed wind speed, and would no longer be optimal elsewhere. So there's little point in it. Only so much you're going to get out of a 50cc engine, and if the gears are already fairly close (which they will be since the speed range isn't very high), there's likely little to be gained. Switching sprockets will just shift the optimums around a bit - you may get lucky for that specific hill, but there will be another you're slower on.
And you'll almost certainly either lose low-speed acceleration or top speed, depending on which way you go - and it's not obvious which one is the way to go, because the gearing that maps that road speed to max power RPM will currently be somewhere in the middle, not at either end, so finding the optimum with sprockets rather than gearbox changes is just shifting around the peaks, as it were.
I toured Wales (on my way to Ireland) on my SH300 scooter, 27HP 280cc engine. It still fell back to 40mph at full throttle on one very steep hill. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| Walloper |
 Posted: 19:05 - 14 Nov 2012 Post subject: |
| barrkel wrote: | | Walloper wrote: | But we were presented with:
I toured Wales (on my way to Ireland) on my SH300 scooter, 27HP 280cc engine. It still fell back to 40mph at full throttle on one very steep hill. |
It's a Ped man..... There is not much to play with in there without remapping ...everything.
You cannot get two pints out of a one pint bottle. (walloper's 2nd law of Binge-ing) ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Hangear |
| Walloper |
The last post was made 13 years, 326 days ago. Instead of replying here, would creating a new thread be more useful? |
