Clutch needed to start
kingsknight
PostPosted: 15:39 - 13 Nov 2012    Post subject: Clutch needed to start Reply with quote
So I'v I parked up my DR125SM on a 11 plate for the last 6 months as I'v been walking to work. I went to go out on it last night for the first time thinking the battery would be dead but I was wrong.
The battery was fine, but my bike needs the clutch pulled in to start now. It's like the bike thinks its still in gear when its not. I could just cross over the wiring to fix the problem or just pull in the clutch every time I want to start it.
took it on a longish ride to see if that would fix it but it didnt.
any advice chaps?
thanks
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
andys675
PostPosted: 16:01 - 13 Nov 2012    Post subject: Reply with quote
it's a standard feature on suzuki's and triumphs.............
StevRS
PostPosted: 16:16 - 13 Nov 2012    Post subject: Reply with quote
Removed - Answering a completely different question.
MV Agusta Brutale 800 RR, Unfinished 1978 XS250
PostPosted: 16:24 - 13 Nov 2012    Post subject: Reply with quote
Standard on Suzukis for many years now, you need to pull the clutch for the starter to work, whether in gear or neutral.
If your 11-plate bike is fuel injected don't bypass the clutch switch. Pulling the clutch in on fuel injected Suzukis invokes the neutral fuelling map.
kingsknight
PostPosted: 19:23 - 13 Nov 2012    Post subject: Reply with quote
im pretty sure i never used to need the clutch
geordiecbrblo...
PostPosted: 21:44 - 13 Nov 2012    Post subject: Reply with quote
+ 1
jimspeed
PostPosted: 23:37 - 13 Nov 2012    Post subject: Reply with quote
maybe the clutch switch was faulty before and now its working again, could have been a sticky contact maybe?
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
kingsknight
PostPosted: 11:14 - 14 Nov 2012    Post subject: Reply with quote
you guys are right. i just completely forgot i needed the clutch pulled in. thanks for the help guys! it had just been ages since i started the poor thing.
The last post was made 13 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.41 - MySQL Queries: 14 - Page Size: 56.03 Kb
