cleaning chrome header pipes
gandy666
PostPosted: 12:07 - 12 Nov 2012    Post subject: cleaning chrome header pipes Reply with quote
hi all
using my bike in all weather, 500 miles a week and the headers are on the turn from shiney chrome to some rusty spots.
any advise on the best way to clean them up - was going to use super fine steel wool and brasso but was thinking i might take the chrome plating off.
then thought about autosol but its not really abrasive enough to get the rust off.
also oxalic acid I could use, but it has to stay on for a while which is difficult to achieve on a smooth horizontal surface.
dont want to leave it to get bad so would rather nip it in the bud.
any of you guys have cunning methods you can share?
cheers
Walloper
PostPosted: 13:11 - 12 Nov 2012    Post subject: Re: cleaning chrome header pipes Reply with quote
gandy666 wrote:
hi all
cheers
Ye canny 'clean' chrome as such. It is an electro plated film of chromium oxides and stuff.
If the rust has got to it then all you can hope to do is 'polish' out the rust spots which will involve a lot of elbow grease and polish.
The acids for doing this job are really meant for stainless steel. They may get the rust off though.
Use ACF 50 on the pipes to help ward off new corrosion but it is only a very temporary temporary fix. A lot of hard graft for very little long lasting effect.
gandy666
PostPosted: 14:23 - 12 Nov 2012    Post subject: Reply with quote
aye the acf50 stuff has been mentioned tae me afore.
sounds like just the ticket
PostPosted: 16:02 - 12 Nov 2012    Post subject: Reply with quote
Don't know about your header pipes but mine almost get to the glowing stage after a good thrash...Suspect acf50 would get burnt off.
Keeping chrome as is = rinse/wipe after every ride in winter.
I have a 32yr old bike with original header pipes. They've lasted that long because some saddo has cleaned them at every opportunity.
mark111
PostPosted: 18:04 - 12 Nov 2012    Post subject: Reply with quote
If it's only light rust WD-40 and rub with aluminium foil Smile
Walloper
PostPosted: 13:48 - 13 Nov 2012    Post subject: Reply with quote
It's good for hot surfaces including exhausts. Where it will 'slow down' if not stop corrosion.
Tip: Run the engine outside the garage or at least have both doors open as this 'process' makes a hoowur of an amount of smoke. Embarassed
The last post was made 13 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.47 - MySQL Queries: 14 - Page Size: 48.81 Kb
