mikojh |
 mikojh Nitrous Nuisance
Fizzer Thou |
 Posted: 14:42 - 15 Nov 2012 Post subject: |
I would send it to Draper UK or try these people
https://alltite.net/mobile-equipment-calibration-by-mobilecal/
If you depend on accurate settings then it is a good idea to have items like torque wrenches calibrated regularly.I have four of them and get them done every six months or so. ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
mikojh |
Fizzer Thou |
mikojh |
chris-red |
Walloper |
 Walloper Super Spammer
mikojh |
mikojh |
Pete. |
 Pete. Super Spammer
 Posted: 19:37 - 15 Nov 2012 Post subject: |
Check it against another torque wrench. If they both click at the same time when set to the same torque setting it's a pretty safe bet that they are both reading correct. ____________________ a.k.a 'Geri'
mikojh |
Polarbear |
 Polarbear Super Spammer
kramdra |
 kramdra World Chat Champion
mikojh |
covent.gardens |
 covent.gardens World Clap Champion
nickerbelly |
 nickerbelly Derestricted Danger
 Posted: 21:45 - 15 Nov 2012 Post subject: |
Polarbear |
Walloper |
 Posted: 03:29 - 16 Nov 2012 Post subject: |
I read on bcf recently that people don't use torque wrenches now as they can't be bothered.
If there is no Zero mark then do not wind it past the lowest number.
That instruction is possibly to prevent unwinding the center tensioning bolt off the core of the universe. Which maintains our planet's orbital equilibrium.
You know wot you've just gone and done now don't you..
 ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
mikojh |
mikojh |
mikojh |
nickerbelly |
 Posted: 20:40 - 16 Nov 2012 Post subject: |
First off mate, there is no such thing as a daft question , and secondly - it's up to you if you want to get the replacement - probably wouldn't hurt if they're offering you a new one , but I personally take manufacturers instructions with a pinch of salt - they can be an anal bunch at times!! - I've always wound the spring tension off completely when not in use and never had any problems at all, the only thing I would say is before you use it just wind it up and down a couple of times first then set your desired torque and that should make sure the spring is properly seated. ____________________ there is a fine line between madness and genius - I have a foot on each side!!  |
mikojh |
The last post was made 12 years, 329 days ago. Instead of replying here, would creating a new thread be more useful? |
