Why is my coolant brown?
guile
PostPosted: 19:09 - 19 Nov 2012    Post subject: Why is my coolant brown? Reply with quote
Only had this bike a few weeks (ER6F) and when I first got it I ntoiced there was no coolant at all in the reservoir. I filled it up with Halfords orange coolant and water (50/50). Now I have noticed it has turned into a shitty brown colour when it used to be bright orange.
Any ideas what has happened. The engine oil does not appear to be milky if that helps and the bike did have a fair bit of rust on the downpipes area (not sure if rust can get into the radiator?).
Fisty
PostPosted: 19:12 - 19 Nov 2012    Post subject: Reply with quote
Usually the sign of a boiled motor.
Drain the lot, flush through with clean water and refill with a 50/50 mix of your choice. Keep an eye on it.
Fatter and faster than Fret
guile
PostPosted: 19:49 - 19 Nov 2012    Post subject: Reply with quote
Can you elaborate? The engine overheating leaves a brown residue in the radiator or what?
Not particulary happy that the previous owner has been riding around on it during the summer without any coolant in. Will that damage the bike permanently?
Will try to flush it tomorrow and see what happens.
Fisty
PostPosted: 20:04 - 19 Nov 2012    Post subject: Reply with quote
Yep that.
No chance you have mixed coolants is there? blue + orange = brown.
guile
PostPosted: 20:09 - 19 Nov 2012    Post subject: Reply with quote
When I filled it up I couldnt see any blue in the coolant tank and it looked bright orange after I filled it but I never checked after running the engine so I guess possible there could have been some blue coolant hiding somewhere else other than the coolant tank?
FireStorm-X
PostPosted: 20:20 - 19 Nov 2012    Post subject: Reply with quote
Hi there
Might be worth flushing the cooling system then refilling, should get rid of any carp, but might also show any leaks Sad
bladerunner
PostPosted: 20:46 - 19 Nov 2012    Post subject: Reply with quote
Could also be years old coolant that's degraded and started rusting/ oxidising the engine internals......as above give the system a good flush out....maybe take the rad off so you can flush it with a hose both ways to make sure the rad core is still clear.
Noxious89123
PostPosted: 22:07 - 19 Nov 2012    Post subject: Reply with quote
You filled it with THIS stuff?
Is "organic acid" coolant ok to use in your bike? I'd have thought Kawasaki specified ethylene glycol based stuff.
guile
PostPosted: 22:22 - 19 Nov 2012    Post subject: Reply with quote
I filled it with this similar stuff
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_219452_langId_-1_categoryId_255224#tab1
You're right about what Kawasaki ask for and I think it is ethylene glycol-based. The product details do not mention it but some messages from the Halfordswebteam say it is in the questions about the product section from customers.
CaNsA
PostPosted: 01:11 - 20 Nov 2012    Post subject: Reply with quote
Yes it does.
I clicked on your link, then read the description.
Features & Benefits of halfords advanced antifreeze
5 Year Life
Suitable for all year round - anti freeze / summer coolant
Temperature range from +108C / -34C
Maximum concentration = 50% water / 50% anti freeze
Suitable for most vehicles manufactured after 1998
Silicate free, organic acid technology (OAT) for superior engine protection
Compatible with all vehicle manufacturers' colours of OAT coolants
Enhanced corrosion protection
Aff
PostPosted: 09:04 - 20 Nov 2012    Post subject: Reply with quote
Hahadumbarse wrote:
isn't rad weld brown?
Yup
Electric Bike Project
PostPosted: 11:18 - 20 Nov 2012    Post subject: Reply with quote
You don't know what was in there, so for your own peace of mind, get it all out now and refill with fresh.
Without knowing what it takes, I'd have gone with blue, because it smells purty.
devojunior
PostPosted: 12:40 - 20 Nov 2012    Post subject: Reply with quote
Hi, as said above make sur etheres no leaking of coolent either from the radiator or anywhere else, a good way to check this would be to fabricate an attachment the the radiator fillet cap so you can attach a hose to pressurize the coolant system,
when you have done that and made sure you are water tight it may be a case of the previous eowner only filling up with tap water which will start to rust the innards off the cooling system slightly giving you that brown colour in your coolant.
so test it flush it and keep an eye on it.
serlant
PostPosted: 14:11 - 20 Nov 2012    Post subject: Reply with quote
tip, I filled mine VTR up with coolant after a clutch change, was green, put red coolant in, came out orange, drained it again put another load of red coolant in now red, my guess before was it had green coolant.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
threepot
PostPosted: 14:20 - 20 Nov 2012    Post subject: Reply with quote
I would drain,flush thru then refill with plain water. Run for a day or two then check colour. Dont leave just water in too long tho.
The last post was made 12 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 92.68 Kb
