| Author |
| steven_191 |
 steven_191 Nearly there...
| Back to top |
| steven_191 |
| Back to top |
| AndyB1989 |
 AndyB1989 Scooby Slapper
| Back to top |
| D O G |
 D O G World Chat Champion
 Posted: 10:22 - 01 Dec 2012 Post subject: |
| AndyB1989 wrote: | looks like the headset needs a strip and grease, but for now put it together, leaving the pinch bolts on the stem loose and put weight on it to push the fork up into the bearing.
Then push the stem down on the steerer - does the steerer tube come proud of the new stem ? if so you need another headset spacer. If not, do up the top cap / star nut bolt untill the play and click dissapears and then do up your stems pinch bolts. |
Edited for punctuation so the decent advice is readable.
Personally, if I had it in that state of dismantling the bearings would be definitely stripped, cleaned and regreased before reassembly as suggested above. You might as well. Take careful note of the order which things come apart.
The other thing I would say to check whether the headset is fucked, when all assembled and done up tight, put the front brake hard on, and try to push the bike forward. You will be able to see if the steerer tube has play in the headstock. If it does, then the headset is most likely knackered, definitely so if you can feel clicks and 'rough' feel when you turn the bars.
[added on request of my daughter who is watching] |
| Back to top |
| AndyB1989 |
| Back to top |
| steven_191 |
| Back to top |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| Back to top |
| steven_191 |
| Back to top |
The last post was made 13 years, 328 days ago. Instead of replying here, would creating a new thread be more useful? |
