What's been getting me to work...
lilredmachine
PostPosted: 18:30 - 01 Dec 2012    Post subject: What's been getting me to work... Reply with quote
It's a fuckin Divvy. Naturally.
https://img819.imageshack.us/img819/962/15696410151273147453485.jpg
https://img593.imageshack.us/img593/1065/30279210151273155243485.jpg
https://img248.imageshack.us/img248/6991/40008310151273176333485.jpg
Found in a garage, sat unused for a year, went straight through the MOT. 1993/4, 21,000 miles, £400.
Just realised I hadn't ever posted about it. It is unremarkable in any way, other than someone has cut a bit of foam out of the seat for a short arse, it still wears the original exhausts, and it's in really, really nice nick for the year.
Frost
PostPosted: 18:46 - 01 Dec 2012    Post subject: Reply with quote
They satisfy every criteria for being a great bike, with the exception of excitement.
lilredmachine
PostPosted: 19:24 - 01 Dec 2012    Post subject: Reply with quote
Damn straight. The motor is the most linear I've ever experienced. May as well be electric.
Ja7
PostPosted: 20:41 - 01 Dec 2012    Post subject: Reply with quote
I had one for two years never let me down, they are good funny really
sidewinder
PostPosted: 15:08 - 02 Dec 2012    Post subject: Reply with quote
had mine over 12mnths and given it hell.Still starts on the button and run really well .There known as the vauxhall astra diesel of the bike world for a reason......... Very Happy
TUG
PostPosted: 15:57 - 02 Dec 2012    Post subject: Reply with quote
Whats wrong with the CBR-F in the background?
Haz ER-5, innit!
RhynoCZ
PostPosted: 16:00 - 02 Dec 2012    Post subject: Reply with quote
How's the engine? Is it really that dull as people say?
lilredmachine
PostPosted: 18:13 - 02 Dec 2012    Post subject: Reply with quote
I hope it's not a CBR, there'd be something seriously wrong with it as it sports a V4.
It's a 1988 RC24 VFR750 'J' which needs a fair amount of work. Thread is here:
https://www.bikechatforums.com/viewtopic.php?p=3410982#3410982
Yup. It really is. Not quite as dull as a Deauville but pretty close.
Electric start went out today. Made a noise like a dying giraffe then refused to turn over. Oddly, I dont get an oil light, when I hit the starter button the relay clicks and it flashes the oil light for as long as you hold the button down. Bike is full of oil and bump starts and runs fine. Any ideas?
RhynoCZ
PostPosted: 19:05 - 02 Dec 2012    Post subject: Reply with quote
Check the starter solenoid, or battery. It also could be the ''carbon/coal'', the same thing as in the drill, if that's not good, the starter won't have enough ''power'' to turn the engine.
The ''oil light'' is oil pressure check, if you've got insufficient oil pressure, the check light glows.
If the starter works alright, the light should turn off even if the engine doesn't run yet and you just turn the engine with the starter.
mysterious_rider
PostPosted: 19:14 - 02 Dec 2012    Post subject: Reply with quote
This only applies if the engine is running. If it's not and the ignition is on (dash lit up) its just flagged on to test that the bulb indeed works (dead bulb would be tragic no?)
lilredmachine
PostPosted: 19:15 - 02 Dec 2012    Post subject: Reply with quote
That's whats odd. The oil light is supposed to show when the ignition is live and the motor is not running. When the motor turns over, the oil pressure (hopefully) rises and the oil light is (hopefully) extinguished.
At the moment I get no oil light when the ignition is turned on, when I press the starter button the solenoid clicks and the oil light comes on for as long as I hold the button down. When released the oil light goes out again.
I think it's a mechanical problem, the starter motor may have given out as it's been flagging recently, but the oil light issue is odd and to me seems like there could be an electrical fault somewhere too.
As I said, when bumped the bike runs fine and every other electrical faculty is functional. I haven't checked the battery yet as it has gone dark but I don't think it is that. I could be wrong though. However I would expect the bike to crank, at least sluggishly, after it has been run for a while as a little bit of charge would have been forced into the battery. This thing is just point blank refusing to even engage the starter at present.
RhynoCZ
PostPosted: 19:23 - 02 Dec 2012    Post subject: Reply with quote
My NC27, I turn the key, theres oil and neutral light, I press the start button and the oil check turns off right away. Confused It might be just a language barrier. Smile
gazeranco
PostPosted: 22:54 - 03 Dec 2012    Post subject: Reply with quote
My mates just picked one up, 12 years old only 7,000 miles. He said its running really nice and keeping him happy on the commute to work. Nice bikes I say!
Bikes Owned:-
Honda Club 90, Honda CB 250, Honda NSR 125, Honda CBR 125, Suzuki RG 125, Yamaha FZR 400 EXUP, Kawasaki ER6F (2011)
weasley
PostPosted: 12:18 - 18 Dec 2012    Post subject: Reply with quote
On the Yamaha, it is an oil level light, not oil pressure (well, it is if it's like my XJ600 was and Thundercat is). Hence, no lighty when ignition on, but it lights up when you push the starter to confirm the bulb is working.
garth
PostPosted: 12:27 - 18 Dec 2012    Post subject: Reply with quote
My old div had the same thing happen, and it was the solenoid.
I actually preferred the xj to the cb500 i recently bought (and sold very shortly afterwards, that thing was duller than dull) for hack purposes.
When you come to sell it pm me first.
c_dug
PostPosted: 12:50 - 18 Dec 2012    Post subject: Reply with quote
This.
Light should come on when you push the starter and if the level drops too low, it is level and not pressure.
Frost
PostPosted: 19:37 - 18 Dec 2012    Post subject: Reply with quote
Also if you go up a really steep hill the light will come on!
lilredmachine
PostPosted: 22:19 - 18 Dec 2012    Post subject: Reply with quote
c_dug wrote:
This.
I'm aware it's an oil level light, however the light used to come on when the ignition was on, then go out when the motor was running. It now doesn't come on with the ignition.
I will look into the solenoid, cheers for the help guys.
Serviced it today, replaced the knackered air filter with a K&N, blew the shit out of the crankcase breather pipe, fitted the correct (for some reason it had CR9, not CR8) grade plugs and iridium at that, a new speedo cable, replaced the oil filter and stuck some decent silkolene in there. It now runs about a billion times better, well chuffed. All that is left to do now is sort out the starter and replace the shit tires on it.
The last post was made 13 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 101.09 Kb
