Honda nsr 125 Foxeye - New ignition coil, spark plug no spar
5ymple
PostPosted: 13:23 - 01 Dec 2012    Post subject: Honda nsr 125 Foxeye - New ignition coil, spark plug no spar Reply with quote
Hello i am new to the forum and am having problems with my nsr 125 Foxeye.
I recently bought it after it had been stood for 3 years. I paid a garage to do the work needed and all was fine for 1 month. Then last week it wouldn't start.
I was told it would probably be the ignition coil so i replaced it and replaced the spark plug for good measure. Still nothing. Any ideas?
thomp1983
PostPosted: 15:47 - 01 Dec 2012    Post subject: Reply with quote
i take it you've removed the plug put the ht lead on it and held it against the head whilst trying to start it to actually check for a spark instead of just going of what someone's told you? if so then you'll need to get a multimeter and start checking your getting power to the components in the ignition system then go from there
chris
5ymple
PostPosted: 14:50 - 02 Dec 2012    Post subject: Reply with quote
Ok thank you very much for the reply but i have a feeling that it may be another problem. When i hit the ignition switch and open the revs it just makes a chugging sound??? Any ideas?
5ymple
PostPosted: 15:27 - 02 Dec 2012    Post subject: Reply with quote
Whenever i press the ignition switch it clicks once from the box next to the battery? This was following on from my previous problem where i could not get a spark after changing the ignition coil and spark plug.
Any ideas? I am in need of this bike as i have serious transport issues this week. This is last day i can try to fix it Sad
Ja7
PostPosted: 18:04 - 02 Dec 2012    Post subject: Reply with quote
Maybe try charging the battery, jump leads from a car, or a bump start, sounds like a battery, the cold and frost kills battery's this time of year.
The last post was made 13 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.6 - MySQL Queries: 14 - Page Size: 42.6 Kb
