ybr 125 help :)
bob_711
PostPosted: 14:04 - 03 Dec 2012    Post subject: ybr 125 help :) Reply with quote
Hi im newish to bikes so still learning with all the things that need to be maintained,i have a ybr 125 2006 which is a carb model and ive de-greased & re oiled chain & made sure its tight enough, ive ordered a new spark plug and air filter and now done 1000 miles on it since i got it so changed the oil which had clumps of white stuff in? if anyone shed any light on that i dont know and now come to check air filter & to clean out filter housing and it has brown gunk in it any ideas? thanks https://img204.imageshack.us/img204/548/airfilter.jpg
Aff
PostPosted: 14:06 - 03 Dec 2012    Post subject: Reply with quote
It means you have water/coolant in your oil.
Do you do lots of short journeys?
Edit: That picture is pretty small cant really see whats going on, can you see where the gunk in the airbox is coming from?
Electric Bike Project
bob_711
PostPosted: 14:46 - 03 Dec 2012    Post subject: Reply with quote
well i only really use my bike for work and my journey to work is around 10 miles so im assuming that's a short journey https://i48.tinypic.com/sdzhg1.jpg
Aff
PostPosted: 14:57 - 03 Dec 2012    Post subject: Reply with quote
Someone more knowledgeable on ybr's will hopefully be along soon, does the crankcase breather vent into the airbox? If so i imagine that pipe will also be full of gunk. Its most likely from condensation and some oil vapor mixing with the damp air in the airbox. Change the oil and take the bike for a good long run, hopefully it will sort it out.
neil.
PostPosted: 19:36 - 03 Dec 2012    Post subject: Reply with quote
I wouldn't be alarmed by that. Yes the crankcase does vent to the air box and a bit of emulsification is normal there (speaking from the experience of owning a 2005 YBR for 40k miles), especially if you do short journeys. Could be that whoever had it before you did shorter journeys than you which is why there's that much in there, but it isn't terrible and I wouldn't worry about it. Just detach that nipple at the bottom and empty it out as part of each service.
bob_711
PostPosted: 20:32 - 03 Dec 2012    Post subject: Reply with quote
well when i got it i took air filter out whilst nosying around the bike and at the time was only a little oil in the bottom of it which i wiped out so will have all gathered from use from me but as long as its not sign of something bad its ok Smile
Aff
PostPosted: 21:13 - 03 Dec 2012    Post subject: Reply with quote
Just take it for a good run every now and then, to burn off the water. Thumbs Up
mysterious_rider
PostPosted: 21:25 - 03 Dec 2012    Post subject: Reply with quote
I'd put that tube into an empty sideways red bull mini can or something, so it doesn't mess up your filter. Thumbs Up
The last post was made 13 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 56.26 Kb
