TZr250 Question???
dtmaster
PostPosted: 00:27 - 01 Jun 2004    Post subject: TZr250 Question??? Reply with quote
does anyone here know if a powervalve servo kit of a tzr250 will fit on a 1993 dt and fully derestrict it? i ve tried the other forums but nobody really knows.
Cheers Ross
1993 Yamaha DT125r
stevo as b4
PostPosted: 00:36 - 01 Jun 2004    Post subject: Reply with quote
I doubt it, as the set up on the 250 might be very different to the DT/TZR125. The CDI's would be different, and so would the ignition advance curves compared to the TZR250. I doubt that the plugg connectors from the P.V. motor to the CDI box are the same for this reason. You need either a full P.V. kit for a TZR125, or else get all the bits from a late DT125R, including the P.V. and servomotor, and the cables etc. This should plug into your CDI unit, but the Pullys and cable might need adjusting to get the correct movement from closed to full open position.
The last post was made 21 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.65 - MySQL Queries: 14 - Page Size: 31.03 Kb
