| ather7on |
 ather7on Derestricted Danger
| P.addy |
 P.addy Red Rocket
| ather7on |
| P.addy |
 P.addy Red Rocket
| steveh |
 steveh World Chat Champion
| ather7on |
| P.addy |
 P.addy Red Rocket
 Posted: 18:02 - 03 Jan 2013 Post subject: |
put a bit of 2 stroke oil down the spark plug hole, put the tester on again and try it again.
If you get a higher reading, top end time Possibly get away with rings, but the piston is a serviceable item. |
| thomp1983 |
 thomp1983 Crazy Courier
| pits |
 pits World Chat Champion
 Posted: 03:57 - 04 Jan 2013 Post subject: |
you want around 150psi of compression....120 and consider rebuilding it.
30 psi, in short she is fucked, like proper fucked, I would imagine new top and bottom end, you have had the head off but no mention (as far as I can see) about replacing the head gasket with the correct size, there are 3 gaskets depending on compression ratio the bike itself has, very complicated involves oil and syringes and stuff.
I think you have a more serious issue than your oil pump, which iirc only works when the engine is running, but don't quote me on that, either way you have no compression at all, consider new barrel and piston, check the bottom end for end float, 30 psi, you may as well blow the piston up and down. ____________________ Stinkwheel: You have no right to free speech
00:33:00 Blau Zedong: the CB400 is my favourite road bike |
| ather7on |
 Posted: 15:49 - 04 Jan 2013 Post subject: |
| pits wrote: | you want around 150psi of compression....120 and consider rebuilding it.
I think you have a more serious issue than your oil pump, which iirc only works when the engine is running, but don't quote me on that, either way you have no compression at all, consider new barrel and piston, check the bottom end for end float, 30 psi, you may as well blow the piston up and down. | we hav changed the base gasket, cylinder head cover, cylinder head cover seal, cylinder head seal and spark plug seal, like i said iv measured the piston, rings and cylinder bore and they seem ok compared to the book settings, just tried starting the bike and it seems very flat, wont start, but oil pump seems ok (it comes along the pipe a little when trying to start it), also coolant seems to be disappearing???? topped up and topped up but always seems empty with no mark left on cardboard under bike? ideas? im not very good with bikes (obviously!) thanks. |
| P.addy |
 P.addy Red Rocket
| pits |
 Posted: 17:27 - 04 Jan 2013 Post subject: |
| ather7on wrote: | | pits wrote: | you want around 150psi of compression....120 and consider rebuilding it.
Did you measure the compression ratio and fit the correct gasket?
There are 3 gaskets, depending on compression ratio you need to find out what gasket is to be used.
0.3m 0.5m and 0.8m and a very complex way of measuring it, you need to put the piston TDC and measure exactly with a syringe how much two stroke oil takes up the space between the head and piston.
Then there is some maths, which works out the compression ratio, which then tells you what gasket you need to use.
I would go one of three ways here
1. She's fucked
2. She has a cracked blocked
3. You have used the wrong gasket and basically it has no compression ____________________ Stinkwheel: You have no right to free speech
The last post was made 13 years, 320 days ago. Instead of replying here, would creating a new thread be more useful? |
