| Author |
| Korn |
 Korn Admin
 Posted: 00:29 - 08 Jun 2004 Post subject: R1 Electrics [HELP!] |
5 headlight bulbs in 2 months, this is not on
Am I right in thinking it could be the rectifier? I noticed today that it gets incredibly hot, so much so that it's melted some of the plastic in its plug. I'm going to attach a small 12v fan to it tomorrow, but what I want to know is could the heat alone be causing the bulb-blowage or does it sound like the rectifier needs replacing? Or have I missed the plot completely?
Everything else electrical I have no complaints with, it's charging fine and the battery seems to hold plenty of juice - it's just it keeps eating these bloody bulbs  ____________________ 3516 Miles, 11 Countries |
| Back to top |
| william |
 william Nova Slayer
| Back to top |
| Korn |
 Korn Admin
 Posted: 01:16 - 08 Jun 2004 Post subject: |
Ahh, yes. Looks well toasted
Time to repair the crispy contact and stick a fan on it methinks, then see if it goes through any more bulbs. ____________________ 3516 Miles, 11 Countries |
| Back to top |
| Kickstart |
 Kickstart The Oracle
| Back to top |
| Kickstart |
 Posted: 01:22 - 08 Jun 2004 Post subject: |
Eeek. Yep, looks like something is putting out too much current.
Check the contacts are clean though. Also ensure that the there is nothing putting a large load on the battery (eg, alarm almost killing the battery so that it has to try like mad to charge it when started).
Bulbs die from old age (not that yours have a chance), vibration and from too much power going through them. Given that I think you are probably right that the regulator has gone.
| Back to top |
| Korn |
 Korn Admin
 Posted: 11:07 - 08 Jun 2004 Post subject: |
Right, cleaned up the crispy contact this morning and plugged the reg/rec back in then tested the battery with the bike off, 12v. Fired the bike up, 14v. Let it warm up and gave it some abuse, still 14v.
Took it to work - about a 40 minute journey - with the headlights on, then turned it off and did the test again. Off, 12v. Running, 13v. Much revvage, still 13v. The whole bike was roasting hot and the radiator fan had kicked in, dunno if that accounts for the drop or not?
Couldn't get it to spike though, this is a good sign no?  ____________________ 3516 Miles, 11 Countries |
| Back to top |
| Claud 14.7 to 1 |
 Claud 14.7 to 1 World Chat Champion
 Posted: 11:52 - 08 Jun 2004 Post subject: |
if it helps, the reg/rec not only manages the power coing back to the battery, but controlls the lights as well. sorry about but not being technical enough, but i forgot what does what, was a time ago.
i had a charging problem on my honda cbr400. lights were ok. turns out the reg/rec went. my symptoms were; it would get very hot within a few seconds. Although they do get hot by nature they should not get that hot so quickely and def not fry. i upgraded to a heavy duty unit, without a fan but with many cooling fins i also used some silicon cooling compound to diccipate the heat to the bikes frame, the same as used for cpu/heatsink applications.
id say the part of your reg/rec COULD have gone, seeing as its burnt.
also check grounds for the lighting stystem. you could check for continuity along the wiring. check for corroded contacts.points along the whole wiring (if its not too much trouble). Could just be a dodgey ground...
my bike is old and i found that some contacts were very badly corroded. cleaned them up with contace cleaner/file.
the other way i tested the unit (for charging) was to warm up engine and put all lights on ie brake, indicators, headlights then check the power going into the batt, at about 5000rpm. this puts the bike under real life conditions. ive got about 13.2v which is fine...(with the new reg/rec fitted) old one was more like 11v
get a haynes manual they are very good for advice and repairs etc!
good luck
just hope it nothing worst like stator windings/stator etc. shouldnt be though
| Back to top |
| Claud 14.7 to 1 |
| Back to top |
| Korn |
 Korn Admin
 Posted: 11:57 - 08 Jun 2004 Post subject: |
Haynes manual says "Consult Yamaha for regulator/rectifier testing procedure". Yamaha manual says "You can't test it, buy a new one"  ____________________ 3516 Miles, 11 Countries |
| Back to top |
| Claud 14.7 to 1 |
 Posted: 12:09 - 08 Jun 2004 Post subject: |
so you say it still works fine even though it appeared burnt. and the problem is intermittant, ie the bulbs blow occasionally. there is no other problems?
know anyone that has the same r1, you can swap them over and test the reg/recs.
btw are you sure you are using the right wattage bulbs? mines a jap bike so although the bulbs appear to look like 472s they need a lower wattage bulb. higher ones apparently cause my bike problems. check that out. the standard 472 are somthing like 55/60 the ones i need are more like 35/50. may be worth a try. That what i was told could be the problem when i was investigating on mine.
checked the gounds/contacts?
eletrics are bitches, especially intermittant ones. my bike simply cut out randomly when i was riding. the batt was so flat after it cut out, it didnt even turn over . |
| Back to top |
| Claud 14.7 to 1 |
| Back to top |
| Korn |
 Korn Admin
 Posted: 00:37 - 09 Jun 2004 Post subject: |
One trip to Maplin's later and I've rigged the rectifier with it's own fan. It's a bit silly of Yamaha to mount it to the plastic battery tray instead of the frame where it could at least dissipate some heat
Anyway, put new bulbs in and took it for a ride - none blown. So far so good. ____________________ 3516 Miles, 11 Countries |
| Back to top |
| Claud 14.7 to 1 |
| Back to top |
| Demonic69 |
 Demonic69 The Pink Rhino
 Posted: 11:02 - 09 Jun 2004 Post subject: |
Korn at least yours has fins to help. Most honda ones are just plain black with no form of heat dissipation at all  ____________________ Back on a Blade. Just feels so right. |
| Back to top |
| Korn |
 Korn Admin
 Posted: 11:10 - 09 Jun 2004 Post subject: |
Honda electrics are a lot better IMHO. I never had any problems with the NSR/RVF/VTR but all my SR's & the R1 have had gremlins. ____________________ 3516 Miles, 11 Countries |
| Back to top |
| Claud 14.7 to 1 |
| Back to top |
| william |
 william Nova Slayer
| Back to top |
| william |
 william Nova Slayer
 Posted: 20:54 - 12 Jun 2004 Post subject: |
Korn,
You might want to check this out if you do need a new regulator now - or in the future.
I am tempted and I havn't got a problem YET.
https://www.electrexworld.co.uk/erol.html#1x0&&
William |
| Back to top |
The last post was made 22 years, 112 days ago. Instead of replying here, would creating a new thread be more useful? |
