Repairing a headset mic
TUG
PostPosted: 18:47 - 12 Feb 2013    Post subject: Repairing a headset mic Reply with quote
Brother broke his mic no doubt screaming down it etc, anyway, i have a replacement but there seems to be a copper wire, easy but then...
There seems to be a blue plastic/fibre type of wire, i was wondering how do i go about soldering that?
Thanks,
Ben
Haz ER-5, innit!
neil.
PostPosted: 19:57 - 12 Feb 2013    Post subject: Reply with quote
Sounds like enameled cable, I guess you can't see any insulation? Very common on consumer headphones etc. Just solder it directly but use lots of heat to make the enamel melt/bubble off. Best tin it first, as the solder will only flow to the bare copper so you know it'll conduct properly.
TUG
PostPosted: 21:52 - 12 Feb 2013    Post subject: Reply with quote
I didn't know if anyone was going to reply because normally people just throw away their headsets and replace them so I did the best I could.
The blue wire I spoke of had a clear insulation coating so using a scalpel I cut it back, tested I had the mic the correct way and soldered it on using a pair of pliers as a heat sink. It was fairly difficult but managed it in the end and my brother is happy so all's well!
Thanks and have some Karma,
Ben
Haz ER-5, innit!
The last post was made 13 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 2.49 - MySQL Queries: 14 - Page Size: 35.47 Kb
